Xray T1
#1876
mike with last weeks lay out we were running 27.37 but as i said was with a fast open lay out with this tighter lay out you will probally want to start at 26 until you find what comfortable.
#1877
Thanks Mike... I thought that you said 27 rollout but was not sure. Jsut wanted to get a good range of Pinions today.
Mike Webb
Mike Webb
#1878
Discussions with myself.
Well I volunteered at Octoberfast and got to have a look see at all the cars. All of the guys cars were running c hub f/r on foam with violets springs and 50 weight shock oil. Now here is the bizarre part. I witnessed on of the factory guy replacing his 6 ceel chassis. It was actually tweeked! Yeah I know ! Appearantly the swiss cheese chassis develops a tweak over time under high load carpet racing. Go figure! .. So I check my chassis plate and sure enough ..I was tweeked to! Well I managed to put my old chassis (1st Gen) and old deck and whalla ! Carpet handling dream! The car is so much stiffer in it's original configuration. Which makes me wonder why they went 6 cell on the evo 2? Any insight? Is because the Xray is primarly designed for asphalt use?
Anyone please comment!
SWG
SWG
#1879
Thanks for the info SWG, wish I would've known that during the race.... oh well. Notice which top deck they used???
Results from Mod Sedan A-Main...
1)Josh Cyrul
2)Paul Lemieux
3)Andrew Gray
4)Brian Kinwald
5)Mike Blackstock
6)Dave Kurshner
7)Jared Scott
8)Travis Schreven (Xray)
9)Ralph Burch (Xray)
10)Mark Adams
Travis Schreven also won the Stock Sedan A-Main. All the A-Main results are posted at the OctoberFast thread in Electric Forums at Trinity Tech Talk. Also, I would assume the track's website will be updated farily soon. www.twincityhobby.com
1)Josh Cyrul
2)Paul Lemieux
3)Andrew Gray
4)Brian Kinwald
5)Mike Blackstock
6)Dave Kurshner
7)Jared Scott
10)Mark Adams
#1880
Looks like he has the Flex Top Deck
http://www.mytsn.com/events/glrimage...958&imid=20865
#1881
simulated wood- are u saying the non-evo chassis is the better one for carpet?
and it doesnt make any sense to me why anyone would want a flexable car on carpet, or at least that flexable.
also i know the sticker on the tire said ellegi, but those looked like TRC tires to me, anyone know what they were running?
#1884
huh.. u think then that ellegi would make a plaid tire for them to use on carpet, if xray is going through the trouble of racing in all in triple crown races and other carpet stuff.
#1885
is the evo2 good for asphault? and what is a good setup for a preaty tight track for stock and mod.
#1886
teamAE, the Evo2 and T1 are made for asphalt!!! I set up my car running a mod and if I switch to stock, it's dialed.
#1887
teamAE :: You have asked a similar question two other times I think. Buy one and see for yourself what you are missing out on....mmmm-kay.
You will have access to setup sheets in the VIP room and excellent support here in this thread, like other models do in their respective threads.
Give it a go!
Give it a go!
#1888
New parts pics are yup on MY TSN, new front casterr block for the c hub setup (6 and 0 degree), new front shocktower with 1 more set of holes further out and all the holes are lower so you can set the ride height higher without having to crank the threaded bit right down and alloy suspension balls for the std piviot ball suspension. Rick
#1889
Rick, I like the aluminum balls. They should shed alot of weight off the car (like it needs it) and allow more or better weight placement. Downside, they will most likely break much easier. I keep looking at the aluminum shock bodies too, just for the looks not performance.
I'm picking up the stock T1 chassis and top deck for the Evo. I liked it better then the 6 cell chassis. Less flex. I race on carpet almost exclusively so I need the car to be solid. My T1 was great on carpet. I need to get the Evo back to the way my T1 was.
#1890
I wanna get one but am trying to chose which one to get and the more I think about the xray the more I like it. I did ask before but to lasy to look back and find it. I have to sell my mission first so...
I will be here for help though
