New Team CRC Gen-XL
#378
Well, you knew this question was coming after this weekends indoor championship. What are some setups that were use this weekend? Pref. Mod setups. The car is always dialed in stock. Thanks guys!!!
#379
Buran's Gen X Setup 1.12th Mod
.50 fronts
5 degree blocks
30,000wt lube on the kingpins
Upper brace long arm, lower carbon brace w/ center cut out
all shims back (max caster) 8 degrees
.25 degrees camber
servo up
CRC Magenta Front 1.61 Glued
Gold Center spring
White Sides set "dead" .5 degrees of deflection in dead spot
30wt oil in shock
30,000wt in the tubes
CRC Hard Pink Rear 1.65
Batteries Forward
Ride Height 3.5mm in front and rear
1.5mm of pod drop
black art body
LRP SXX Speedo, profile 1
LRP X-12 4.10 24/96
5 degree blocks
.25 degrees camber
servo up
Gold Center spring
30wt oil in shock
Batteries Forward
1.5mm of pod drop
black art body
LRP X-12 4.10 24/96
#380
Crc hard pink tire?
#382
What all is needed to use the long upper arms?
#383
Check this thread out, it should be helpfull whynot.
http://www.teamcrc.com/crc/modules.p...ewtopic&t=2034
#384
Regards,
Carter
(who would like to know how this affects the handling of the car)
#385
#388
Anyone with a better explanation of how to tweak the car properly with a "dead area" beneath the side springs???
#390
.50 fronts
5 degree blocks
.25 degrees camber
servo up
Gold Center spring
30wt oil in shock
Batteries Forward
1.5mm of pod drop
black art body
LRP X-12 4.10 24/96
5 degree blocks
.25 degrees camber
servo up
Gold Center spring
30wt oil in shock
Batteries Forward
1.5mm of pod drop
black art body
LRP X-12 4.10 24/96
