XERUN V2.0 Brushless ESC discussion thread.
#901
I thought this was a typo when I saw it but asked the seller and it's confirmed !!
£71 INCLUDING Postage to the UK for the 120Amp Blue Spirit !!!!!!!
http://cgi.ebay.co.uk/XeRUN-1-10-RC-...item51934755f8
Bloody Hell that's Cheap !!!!!!!!!!!
#902
Ungrateful
the thanks i get for updating your speedo. its too fast! i like it. try settings 4,9 and 15. 4 and 9 lower number and 15 to a higher number. 15 on 6 should give you less out of the bends, 4 and 9 on a lower number to also soften the punch. come up to hrcc on a friday and we can have a little play. regards al.
Joking aside I found that I need a little more finger control to handle the current profile/set-up. I might then up the agrression once I have got used to the extra oomph
#903
Same here much much to throttle heavy and am overheating motors because of it
#904
then again full throttle is so tempting.......
ask cherry about wlrc car set ups, he used to race there.
the cyclone is dead. gone back to xray wooooohooooooo
#905
#906
#907
Well considering they do the old 'gift' trick that is pretty much the landed price, looks like he bulk bought, remember my mate just sent a 120amp back to HW which blew up, they are replacing it free of charge (inside warranty) but the maximum they charge for an out of warranty total loss replacement on the 120amp is £40 gives you an idea of the mark up that ebay man is getting, also gives you a clue to the bloody extortionate markup speed passion are making lol.
#908
HK 2.4G rx =$7 (works perfectly)
spektrum rx $65 ++
Some guys still just refuse to believe anything at 1/2 the price actually works. Keep paying those big $$$$$
#909
You are getting a voltage drop. Fit a cap to the reciever and it will be sorted.
Had the same issues with my EZrun 80amp in my Fusion buggy. I used a 470mfd16v cap fitted onto a servo plug and plugged into the battery channel on the reciever. Alternative is using a ubec or lipo regulater.
#910
#911
#912
#913
Would the bigger 8.5 run cooler than the 3850 size 9t?
#914
120a V2
Got a good testing session with the 120a with the 518 software in 21.5 and 17.5.. I think I am going to be converted no more using my Tekin.. The speedie has a little bit more down the straights then the tekin right at the end of the straight.. feels allot smoother and has more punch through the infield... man I can't believe I putting a $250+AUD speedie on the shelf for one that I purchased for under $100AUD off ebay as a backup.. awsome.
I am running no drag brake but the speedie seems to have more natural drag through the corners when compared with the tekin.
There is one problem I found (well not a problem just a diet issue).. far out this speedie is heavy.. on a Cyclone Exotek I had to go down to 4200 batteries from 5000 with 15g weight to be on weight with the tekin rs and had to slide the battery out to its wides setting to keep the car balanced.
Anyone running this speedie without a fan.. I know it states to run a fan when using the new firmware with adjustable timing.. I just thought a 120a might be able to handle 17.5 or 21.5 with the fan removed.
Cheers
Cheers
#915
Need help !!!
question am trying to update the firmware on my xerun i have the v2 lcd program box but now idea on how to use it on pc or were to find the updates on the net ...?
so i need help on were to start ????:
