XERUN V2.0 Brushless ESC discussion thread.
#496
#497
#498
ok thanks. But the 230 and 231 firmware, it's a beta, no? because i haven't the program card...
#499
#500
The speed control will come pre loaded with I believe HW 323, this is a fairly generic profile.
I would run that with DDRS at 8, Timing at 26.25 with about a 6.0 on the FDR.
Once you have bought a V1.02 LCD programminh card THEN you can begin to experiment with newer (faster) software profiles, but without that little box you cannot do any of the updates.
Hope it helps
Hope it helps
#501
ok thanks a lot. In fact a friend have the PRO card for update the firmware. I have tested the 110 firmware and it's verry good in 10.5 . But, in the future, i want to test the supercharger mode.
Bye
Bye
#502
Today i got back my two XERUN 120 from Hobbywing and both are loaded with the v1.10_091218a_t.Any idea what is this this version for? Mod,stock or whatever.Has anybody try it so far?
#503
it's the 110 software. The same as the speed passion 2.1 ( stockspec ) . I have tested this soft and it's more fast!! with a speed passion V3 10.5 and the timing at 26 . The ratio is 5.1 for a medium track. test this
#504
Fortunately i didn't use it 'cause i have already put my mod motor on.I have to go back to 323 or 205 for this motor.
#505
ok, it's a good choice
#506
a question for supercharger software drivers :
What's your value of the supercharger mode with a 10.5??? 11-16
thanks
thanks
#507
#508
ok thank you. But the motor is not the same...
#509
read them and follow closely the advice for setting up your speedo.
there is no track/motor/battery/car set up/driving style/fdr etc that are identical.
you need a good basic set up(see above), and time to spend adjusting your speedo. it takes time but is worth it when you get there, especially as your less likely to damage your motor or worst your speedo!
good luck and dont forget to post how you get on.
im having ago on friday night, and will post results over the weekend.
#510
Running mod. Is software significant in this class?
