KO PROPO EX-10 Helios q's
#1696
Module
1.) Does anybody know if the Helios EX-10 module (RF-MODULE RF-501F) will work in the older MARS-R.
2.) Also will the older MARS-R accept the HRS module out of the Helios EX-10.
3.) One last question is there away to add more tension to the drop down wheel mine feels kind off loose.
Thanks,
E
Thanks,
E
#1697
old stock
to ko propo staff:
by chance would there be any stock left of the original mars drop down wheel (in blue box)?
i think the one for the mars-r is still available.
(i realize this is not a helios question, but not sure where else to post)
thanks!
thanks!
#1698
Originally Posted by quantum
to ko propo staff:
thanks!
thanks!
The Mars R is the exact same, just with a black case.
-Robert
#1699
thanks for the info!
#1700
Originally Posted by RED-LINE M03
1.)
Thanks,
E
Thanks,
E
Hope it helps,
shiun
#1701
Wheel
Hey guys how do I remove the wheel on my Helios. I bought the rubber gripped kimbro wheel and would like to replace the stock foam wheel. I can remove the stock foam on just by sliding it over the lip of the wheel. But the Kimbro will not go over the outer lip of the wheel. Is there a screw in the center of the wheel so I can slide on the kimbo from the rear? And if there is a screw in the center of the wheel is there a trick on getting the plastic piece off with out breaking it?
Thanks for your time.
Regards,
Eric
Regards,
Eric
#1702
Regards,
Eric
Regards,
Eric
#1703
1. No
2. No
3. answered above
2. No
3. answered above
Thanks,
E
Thanks,
E
#1704
annual ko grand prix
does anyone know if there will be a 4th ko grand prix at the tamiya track this year?
#1706
Hi guys,
At the race last night I had barely any right side steering. I tried to find the EPA's on the radio, but couldn't find it. Can someone point me in the right direction?
#1707
Originally Posted by DOMOisCOOL
Hi guys,
-Robert
#1708
Originally Posted by KO PROPO Staff
Go to Steering Balance. Turn the wheel all the way in the direction that you want to adjust. A star (*) should appear next to the adjustment. Holding it there, turn the dial or hit the + or - buttons to adjust.
-Robert
-Robert
#1709
Can anyone suggest a good mod to make the KO trigger smaller? I'm currently using foam with heat-shrink tubing around it. A friend of mine melted and re-formed his, but I'm not that brave .
#1710
I always wire tie a piece of fuel tubing to the brake side, that way my finger is sandwiched in between it and the trigger with no slop.
