KO PROPO EX-10 Helios q's
#1666
Ok thanks kopropo staff, Another question, Would it be possible to use a 27mhz module and receiver from a mars r radio in a normally 75mhz helios? Like if u take out the module can you use whatever mhz you want or does it have to be the one that it came with?
Thanks again....
Thanks again....
#1667
The mars module fits but not recommended to use in the helios. The reason is because the helios module has a higher output then the mars, thus you would lose range.
The recevier you can use, but will have to change the response mode in the radio according to the receiver that you are using.
#1668
Would i need a 27mhz module for my helios tho to run the mars receiver?
Because i have a 75mhz module and receiver but my friend has a 27mhz module and receiver for his mars, i wanted to use his receiver because i messed mine up.
#1669
Yes you would need a 27MHz module.
#1670
#1673
Originally Posted by Jon Kerr
Hey guys, quick question. Is there a synthesized 27mhz module available for the Helios? I'm looking into getting one but I have 4 Novak Xxtra receivers and don't really want to have to replace all my receivers and buy a bunch of crystals if I can help it.
#1676
sorry to bother you guys, but is it confirmed that the Spektrum Ko Module only works in the Helios and not the Mars R?
#1677
I would see no reason why you could not use the synthesized module from the Z1 in the Helios. They are the same radio, just with different name on them.
#1679
Originally Posted by Mr. Shookie
Hey Jon......
The synth from what I was told is only in 75FM....Someone can correct me but I believe I am right...
THere is no Synth module for 27 that I have ever seen...
There is a Mini Z module that is 27 but you need crystals...
Hope that helps,
-SHookie <><
Hope that helps,
-SHookie <><
The Shookie is right. The JR Z-1 is only 75 fm. It is however a direct replacement into the Helios.
Brant
#1680
rookie question has anyone used the eveready lithium batteries instead of alkaline how long do they last over alkaline
