TA-05 ver.2
#1321
My dampers does not have any rebound.Does it mean that it is spoilt?
#1322
Suspended
Most of the time I can get away with refurbishing the dampers without replacing any parts. If I do replace anything, it's almost always the O-rings.
#1323
Suspended
I will post my setup sheet after work
#1324
Suspended
First setup sheet, before the race coming up on 10/17/2010 -
#1325
Suspended
I am printing out my V2-R manual tonight. I will read it talk about it tomorrow, I suppose.
#1326
What downstop value do you run dragnse7en ?
#1327
Suspended
#1328
Suspended
I'm using 3X10mm grub screws. Measured from the tops of my suspension arms, I have 0.5mm screw height for the front arms, and I have 1mm screw height for the rear arms.
I would think that the measurement should be taken from the bottom of the suspension arms, but I can't really get a gauge in between the chassis and arms to do so.
Hope this helps though!
#1330
Suspended
Updated setting sheet - I added the downstop value in the memo/ notes, and added the upper arm spacer values, which were empty.
#1331
Just received and installed my front spool. Ready to take it to a tennis court tonight or tomorrow to start practicing before my car finally meets a real track!
Is there any secrets or anything I should know while using a spool?
#1332
Suspended
Now consider how you can or cannot brake. Braking out to slide into a holeshot, mild braking, and front/ rear braking are completely different.
Sway bars/ Stab bars:
This will help BIG TIME if you're on a track with all hugs, corners, and winds, and then YAY! a 60ft straight. Believe it or not, the medium weight (yellow) and soft (red) stab bars work the best for the front, after speaking with my R version brotherhood and bretheren.
Ride height:
Get the car's nose lower, if possible here. The car might act like a 2WD car at first, but trust us, it's 4WD but just no longer full-time 4WD.
Bank up on spares and try not to kiss your rear hubs against anything solid b/c it will feel like you can fish-tail or do infinite donut burn records
You will fish-tail thru turns more, but the front end of the car acts more like the new TRF417, with a diff that only goes forward. Any tire that needs traction in this application has 150-200 percent advantage on cornering and steering - if you know how to drive.
Maintenance:
Pull it all apart, and blast all the metal parts with liquid wrench, and let it thoroughly dry!!! - not carb cleaner!!!! Wash all plastic parts in dish detergent and dry, inspect, replace parts as necessary, and then re-assemble. Giggity!!!
More on the center one-way if you wanna know. PM me
#1333
^^^^^ ignore all that...he didn't read your post and instead posted a bunch of stuff about one-ways, not spools (and a bunch of other stuff that didn't have anything to do with your question).
The basic lowdown is that you should find the car easier to drive with a spool. You WILL have maximum four-wheel braking and the car will have more on-power steering than with a front diff. The trade-off is a little less off-power steering.
Just keep an eye on the outdrives for wear. Over time, the dogbone pins tend to wear into the outdrives because running a spool is a little harder on the drivetrain since it doesn't have the "give" that a diff has in an impact.
#1334
Suspended
TA05 series secrets update
Steering maintenance.
Please add to that thread if you also have a trick
http://www.rctech.net/forum/electric...s-secrets.html
#1335
Super Moderator
