Like Tree130Likes
TA-05 ver.2
Old 10-19-2016, 05:29 PM
  #2671
tobyzhang's Avatar
Trader Rating: 15 (100%+)
Originally Posted by KA2AEV
Okay need some advise and suggestions
On my TA05V2 Im running yellow front springs with the red sway bar
The rear springs are yellow also and using the yellow sway bar in the back
The tires were Solaris Slicks on a rubber surface. But the surface
doesn't seem to matter. I gotta find some more grip up front
Its pushing madly!!!
Any suggestions on what to change suspension wise to get more grip?
Mike
TA05v2 has some inherent understeer for some reason. I suggest use shorter front upper link positions to see what it does and also look into BB from blocks or even AA front blocks. Also make sure you don't have excessive rear toe in and rear diff is tight enough. Also more rear droop might be helpful.
tobyzhang is offline
Old 10-19-2016, 06:16 PM
  #2672
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
What bodies is he using ,may have too big of the rear wing!
OVA is offline
Old 10-20-2016, 12:24 PM
  #2673
KA2AEV's Avatar
Hi Guys, thanks for being so fast!!!
Sorry for replying so slow, Im on my Evening tour and it was busy last night!
Anyway I don't think the wing had anything to do with it, but I gotta replace it anyway. We were running at a brand new facility and I got too close to a marshall and when he jumped over my car to avoid the collision, he clipped my wing and broke it anyway!
Im going to try all of the suggestions that you posted one at a time and will see what does and doesn't make a difference. Im gonna try the wing first, since I gotta do that anyway!!!
OVA would the actual height come into play or just the physical size??? (Just thought of this!!!)
KA2AEV is offline
Old 10-20-2016, 12:51 PM
  #2674
OVA
OVA's Avatar
Wing size and shape make a big difference......I am running Tamiya BRZ bodies /with tamiya option racing rear wing , this bodies it is perfect balance for steering and rear end is very stable....
question : Are you running the spool or Gear diff? gear diff will give you more steering for sure
I can shares you my set up..lmk
If your track is small and low grip..I would converter to lay down shock( IFS )
works for me, cause ifs set up is softer and it make the car turn in easy..
OVA is offline
Old 11-06-2016, 11:20 PM
  #2675
OVA
OVA's Avatar
sorry
TTT
OVA is offline
Old 11-07-2016, 05:52 PM
  #2676
KA2AEV's Avatar
Hey guys, Just an Update
I haven't had a chance to do squat on my car lately!
I did get the wing tho! Hopefully this won't get too involved!!!
Mike
KA2AEV is offline
Old 11-07-2016, 11:24 PM
  #2677
Quick question, i messed up my front end during a crash and I need to replace the arms. Currently I have the short reversible arms. Will the 418/419 arms work?
jessele is offline
Old 11-08-2016, 12:19 AM
  #2678
OVA
OVA's Avatar
The 418 or 419 arms will work ,only if you use the upright shock tower, NOT the IFS ..
OVA is offline
Old 11-09-2016, 09:00 PM
  #2679
vlad_sa's Avatar
Did anyone look into getting a floating servo holder in TA05?
Since I'm still awaiting mine to arrive, I'm getting extremely curious!
I'm not sure if there is a extra hole free next to the hole where stock servo holder sits?
If I ever get, which I'm sure I will raceberry chassis for it, it will be modified to fit EXO 5 servo stay
Cheers
vlad_sa is offline
Old 11-09-2016, 09:02 PM
  #2680
vlad_sa's Avatar
Really? So you have to go back to original TA05 arms in order to have the shocks in ISF?
vlad_sa is offline
Old 11-09-2016, 10:48 PM
  #2681
OVA
OVA's Avatar
yes...that is correct...
Original arm have three places for ball connector.. one for the shock ,sway bar and IFS pushrod
The 418 only have two places ball connector( shock and sway bar)
OVA is offline
Old 11-09-2016, 11:18 PM
  #2682
vlad_sa's Avatar
Bummer, I'd have to get some carbon re-enforced parts as I plan to run the shocks in ISF.
vlad_sa is offline
Old 11-10-2016, 10:56 AM
  #2683
OVA
OVA's Avatar
sorry bud....
why do you prefer IFS?
IFS is an excellent for low grip or small track layout
OVA is offline
Old 11-10-2016, 11:22 PM
  #2684
vlad_sa's Avatar
sorry bud....
Because I drive mostly on the small technical track in the local club.
vlad_sa is offline
Old 12-07-2016, 04:25 PM
  #2685
Hey guys ive really been interested in upgrading the chassis im using that came with my ta05 v2r kit. I was noticing there really arent any options online anymore, the 3racing stuff is pretty much all out of stock and the only usable one i found was like $100 and i believe id have to convert my setup to a mostly vdf based design to even use that kit.
Ive been interested in cutting out my own chassis for a custom build setup and it seems relatively easy to pull off. Since i dont see anyone selling or remaking the exotek ex05 for my kit i was thinking i could instead cut a plate of carbon fiber to match that if anyone had a way for me to get a hold of a print out to use for reference points in cutting the CF. I was originally gonna use my stock chassis but id be in heaven if i could setup something more like the ex05.
Does anyone know of a way i could get a hold of something to use as the exotek ex05 reference for me to use to cut out of carbon fiber?
TheMadHatta is offline
