-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Aries326 06-11-2005 11:16 PM
Originally Posted by Team Duratrax
The whole new steering assembly in the TC4 would be a nice change in the TC3 if there is a way to convert it.
Sean
Here's the link to convert it:
http://ca.geocities.com/[email protected]_tc3.htm
Team Duratrax 06-11-2005 11:22 PM
Well there you go :lol: I suppose anything can be done when thought.
Sean
protc3 06-12-2005 01:53 PM
if you wanted to go with a carbon fiber chassis kit,my BMI TC3 kit offers the option of running the nitro and tc4 steering racks in 2 positions for more ackerman adjustment. ;)
NOZ69 06-12-2005 02:34 PM
Speaking of Carbon Fibre Chassis`s.... :)
I was thinking of getting a TC4 CF Chassis kit & retro fitting the TC3 driveline to it..WOULD this be possible without to much hassle. "TC3/4 Hybrid" :lol:
My thinking is that by doing this I`ll bring my TC3 up to today`s chassis standards & get some "BLING BLING" too. Also cheaper than buying a new car,if i can use most of the TC3 parts (i`ll change to TC4 steering too).As i can get a TC4 CF chassis kit for around $100-110 USD
Cheers
Charles Leto 06-12-2005 05:16 PM
the CVD's, diffs, trannys, drivline and diff cases are the same between them all
loopedeloop 06-12-2005 05:59 PM
What about bulkheads/shock mount uppers,
ie.
will tc4 SSG silver c/f parts fit the tc3 ?link :
http://www.speedtechrc.com/store/ebp...id=451&id=5159
single peice gear input shafts
http://www.speedtechrc.com/store/ebp...id=445&id=5018
Thanks :D
Charles Leto 06-12-2005 06:06 PM
to much weight to the drivetrain, the shock tower mounts for the FT TC4 and TC4 team are the same as the TC3 only the mounts were changed
if by bulkheads you mean chassis braces where the camber links are on the 4 Team are interchangable with the 3, when it comes to the FT 4 they are diff
to run TC4 towers u need to run TC4 chassis braces
trx1 06-12-2005 06:14 PM
Couldnt you get a peice of CF,or graphite and make your own chassis for the tc3 :confused: and what about plexiglass :confused:
Charles Leto 06-12-2005 06:42 PM
plexi glass is to weak, and to flexible it takes a lot of work to make your own CF chassis, unless your an engineering genious. it takes a lot of measuring and you have to be very precise, Cf is also expensive, if you want a CF chassis BMI is the best way to go
Aries326 06-12-2005 07:17 PM
Technically, you could. There's a guy at my brother's job who is really into racing and he also builds custom chassis for customers. He also charges an arm and a leg... I'm sure most of his designs are copied from existing ones.
trx1 06-12-2005 08:10 PM
well, since i aint rich... there goes that idea :lol:
Charles Leto 06-12-2005 08:12 PM
trx1-have u ever raced at planet R/C????
trx1 06-12-2005 08:21 PM
no i havent the last place i ran was new castle when i ran the legend class 2 yrs ago. since my friends hubby died, i havent had a ride to go racing :( Would LOVE to race again, but with no ride except my scooter...... :cry:
NOZ69 06-12-2005 11:11 PM
Thanks for the replies.. :)
I`ve already looked into this...have sourced some CF sheet for a "slab" of beer, BUT it`s not the best (from a boat builder) in finish so i gave the idea a miss.
Cheers
trx1 06-17-2005 07:43 AM
probs arise....
I found a great place to run, blacktopped lot. close to home tooo. now heres the prob:
Car wants to slide everywhere. no grip with the stock tires/wheels. this is NOT fun at all. would a set of green dot foam tires help at all??
