-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Shalala 09-05-2004 08:22 AM
woo woo , all blue parts , quit Good looking......only......
DaveW 09-06-2004 08:13 AM
How did everyones racing go this weekend?
- DaveW
lem2 09-06-2004 08:58 AM
Re: Tamiya SHocks
Originally posted by Blakesrc
Hey Guys,
Anybody using the tamiya shocks on their tc3? I just picked up a used tc3 and it has tamiya shocks on it. I rebuilt them last night but noticed that the stock associated pistons wont fit in them. Should i just stick with the tamiya pistons or is there a better alternative?
Thanks,
Blake
Use the tamiya ones, but if you want the AE ones, you'd have to take out a sand paper and carefully sand wach one until it fits perfectly.
donoman 09-06-2004 09:44 PM
Anyone use a servo saver in conjunction with the crappy little TC3 servo saver? I have a KO Propo 2343... What do you guys recommend?
johnbull 09-07-2004 12:19 AM
The blue TC3 looks nice but I bet it weighs a ton.
The NTC3 hubs and arms are interesting.
donoman 09-07-2004 12:59 AM
I am asking about a servo saver because I repeatedly strip my servo gears when I'm racing because... well... I suck!?
trackdesigner71 09-07-2004 05:44 AM
Hey, I know that this question has been asked before but I need foam tire information. I am racing this thing on carpet and would appreciate any help you guys could provide. How good are Speedmind foam tires too?
crACkeD ChaSsiS 09-07-2004 07:13 AM
havent been here in a while!!
dang havent been here for a while.college really takin over r/c racing.
tc3stocker 09-07-2004 01:25 PM
for carpet you will run TRC 28mm front and 30mm rear with Plaids up front and Purples or double purples in the rear, you will need to true down the tires and you run double purples in the rear if you want a loose car...................there are many different tires combinations that you can use howecer these are the basic ones..................as to Speedmind tires, I would not suggest them, use either Mono tuning, TRC (trinity), Jaco, or any rims you want with TRC donuts
Hope this helps, I used to run the TC3
kh15 09-07-2004 03:01 PM
i got my order from tower today!!!!!
got some new fresh kicks from orion, rear shock tower (snapped the first one), and i finally got the all important camber gauge, so anyway i set my front camber to -1 and i dident want even think to change the back because their just the stock settings but i checked them anyway and one is -4 and the other wheel is -5 thats so messed up lol what should it be like -3?
donoman 09-07-2004 04:13 PM
kh15 guys i know run 1.5 negative camb all around bye
rally 09-07-2004 07:08 PM
Please conduct all selling in the For Sale forum.
Thanks,
Josh
DRIVEN 09-07-2004 08:46 PM
I used to set mine at 1.5 - 2 degrees but I get better tire wear when set to 1 degree all around.
A_Stratus 09-08-2004 05:54 PM
I just milled out my TC3 chassis and I was wondering what that black material is on the side to push the battery towards the drive shaft?
Aaron
BBSpence 09-08-2004 06:00 PM
Aaron
I used weather stripping from Home Depot.
