Originally posted by racerdx6 Wiley- Here's another idea I had to figure out your servo centering problem. One you TX reverse the steering servo. Than try steering left and right. The servo doesn't center after steering right, but it does center after steering left? If the transmitter were the problem, when you reversed the servo, the servo wouldn't center properly on the opposite side it didn't center before. So the servo would center after steering right, but not after steering left. Try this and see if it works. I have a feeling that your transmitter isn't working properly. You could also try the transmitter in a different car and see if it works than. |
Originally posted by wiley racerdx6 - i'll try this...i have been running a stock TC3 which i intend to convert to rally specs once i get my FTTC3 running...i will also try to change the steering parts from this stock TC3 to the FT as the stock one doesnt exhibit this issue |
Umm...i think u forgot about all the aluminum, and the graphite chassis :)
he is just talking about the steering rack..... i think
Originally posted by Hooked The only difference between the FT and Racer kit steering rack is the bearings (FT) and bushings (racer) ... everything else is exactly the same. |
oooo yeah...my bad guys :weird:
Did you guys know there is an editable version of the TC3 setup sheet here- http://www.msra-racing.com/features/setupsheets.htm
It's in Acrobat and looks just like the regular one, but you input your setings and then print it!!! Just like the pros- lol |
Originally posted by BigDogRacing Did you guys know there is an editable version of the TC3 setup sheet here- http://www.msra-racing.com/features/setupsheets.htm It's in Acrobat and looks just like the regular one, but you input your setings and then print it!!! Just like the pros- lol |
don't mind me just checking my gif.
White plastic ring gears and pinion gears
Has anyone used the white plastic ring gears and pinion gears? I can't get them to fit in the differential housing. Anyone else having the same problem. Are there new diff housing for the white gears?
Hi all, new user here. Got a question, I've been using the Novak SS system for several weeks now. I've been having a hard time trying to get rid of an off power push. My setup has gotten a little off the beaten path, but it is driveable.
Just wondering what some of you have done to over come this. I feel like anyone with the SS in a TC3 would have the same problem. Thanks |
If your battery is in the rear position, the easiest way to get rid of the off power push is to move it forward. Otherwise, I would mess with my suspension in order for the car to throw more weight toward the front of the car when I let off the throttle.
Re: White plastic ring gears and pinion gears
Originally posted by Brant Has anyone used the white plastic ring gears and pinion gears? I can't get them to fit in the differential housing. Anyone else having the same problem. Are there new diff housing for the white gears? |
I have an IRS chassis FTTC3 and need some help in setting up the kit. The car seems to hookup during off power and spin out during on power.If I practically slows the car it doesnt hookup. I was thinking of putting in heavier weight oil as it seems that weight transfer from front/rear is very fast.Does putting heavier oil slow the weight transfer?If so what is a good weight to start off with?I have from 30-70wt oil in my pit box.
My setup:- Aspalt medium to high traction Front 35 shore GRP foam 30wt oil red spring 1.5deg camber 4deg caster/no kickup 0deg toe-out camber links long(inner/upper) balldiff/steel diff halves aluminium CVD/pin cushion 5mm ride height droop 6 on Assoc. gauge Rear 35 shore GRP foam 30wt oil blue spring 1.5deg camber 3deg toe in camber links long(inner/upper) balldiff/plastic diff halves composite bones battery upfront 5.5mm ride height droop 4 on Assoc. gauge Once I get the car running right I already have a locked diff and also a one way to try which is better for my local track.If anything is missing from my setup please do let me know so that you guys can help me better Thanks |
Hi guys,I just got a TC3.Can someone shows me what is the best way to solder the battery connector?Seem the normal 3x2 saddle pack with vertical connector doesn't fit any all.
Thanks. |
| All times are GMT -7. It is currently 10:40 AM. |
