Re: mike d ur set up at halloween classic
Originally posted by tc3 racer sc mike d can u post ur set up at the halloween classic and ru going to clevland race this month Front: Yellow springs, 60wt, #3, front tower, shock mount out on tower - in on arm, 0 kickup, 4 caster, camper link up and short on tower, associated steering blocks, .030 bump steer washer, steering rack with standard spacing, .060 sway bar, 4.5mm ride ride height Rear: Purple springs, 50wt, #3, rear tower, shock mount out on tower and arm, F block and 2+2 block, camber link up and long on tower, associated rear hub using upper hole for camber link mount, no swaybar, 5mm ride height Protoform Alfa body with wing mounted forward, batteries forward, front diff tighter then rear, droop equal front and rear (set so chassis height is 8.5 mm front and rear when the tires leave the ground) Jaco Purple rear and Jaco Purple/Orange front, tire diameter 59.5 mm front and rear |
Halloweeen Classic Setup
What that your stock or modified setup?
Re: Halloweeen Classic Setup
Originally posted by Brant What that your stock or modified setup? |
Hey all,
I am about to build up two IRS diffs to use in modified and save my plastic diffs for stock. What I need to know is-I have the old grey DIFF gears , but my car has the White crown gears. Can I mix the two gears or do i need to change the bevel gears out now too? I currently dont own any grey crown gears. Thanks, Ray |
Ray,
That's the way my car was! Actually I thing the front has a white diff gear and a grey crown gear, while the back had the exact opposite... :weird: |
White Plastic Gears
Ray,
The white plastic gears have a high percentage of fiber in them. I finished a design project where I used a material that looked just like the white gears and it was 43% fiberglass! The gray gears have a lesser % fiberglass in them. I got to imagine that the fiberglass is there to give the gear set more life. |
Brant and Greg,
Thanks!! I just dont want to ruin my perfect diffs and outdrives running 19 turns and higher winds!!! Thanks, Ray |
TC3 Droop on Carpet
I'm new to carpet. I guy at the local indoor track whic is smooth carpet told me to remove the droop from my car. Originally I set the droop to what was specified in the manual. Then I set the ride height. Then this guys said to remove the droop, so I ran the droop screws down until they just touched the chassis. How worng is this or does this sound acceptable?
Thanks, John |
Removing Droop
Take a look at the posting about 4 up from this by Mike D, a very fast guy. He is running 4.5mm ride height and then he has enough droop to raise the car an additional 4mm. I can raise my car an additional 2mm with a 5mm ride height, but I'm thinking about adding more droop.
Hey I finally got some pics of my TC3. I just need to wrap up this roll and I will post them up ASAP
Re: my new tc3 ft
Originally posted by sars125 If everything is ok then i get my new tc3 ft this week but now i want to know is: Are there any thing i have to do while bilding the car? I mean to make the car better. Or any Hop-up's? Greetz lars bongers , Holland My englische isn't that good but i hope it works. Happy building! Chris |
Re: Steering rack
Originally posted by Charles I am trying to tighten up steering slop. Does the ntc3 steering system give a better steering system on tc3? Who makes this modification? thx Making the mod, I think you mean making the chassis accept the NTC3 steering. For that you have to cut out the existing chassis flat to accept the steering system. |
MY freind's TC3 arrived to my house this morning.
The frontright is trashed. Wheel hex pin is BROKEN and the metal bushings are gone and the top kingping/ball stud is bent.:cry: Can anyone be SUPER SUPER nice and maybe send the spare metal bushings to my house? :sweat: |
I will be gettinf a FT TC3 for christmas, and everybody at my track uses a one-way, but I can't find one for the tc3.
Originally posted by Intermision I will be gettinf a FT TC3 for christmas, and everybody at my track uses a one-way, but I can't find one for the tc3. |
| All times are GMT -7. It is currently 08:03 AM. |
