The Speed Passion Thread >
Like Tree57Likes
Old 05-05-2009, 04:48 AM
  #181
crabboy's Avatar
Trader Rating: 58 (98%+)
Hi Guys, got my first Speed Pasion 4.0 v2 motor, i have had several people tell me to take the fan out of it and lots of people telling me to leave it in.
I run TC and lipo, can someone please tell me whats the best way to go with the motor.
Rhys
crabboy is offline
Old 05-05-2009, 08:38 AM
  #182
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Rhys
leave the fan in it, you won't notice that much difference.
Marcos.J is offline
Old 05-05-2009, 11:41 AM
  #183
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Rhys
Like Marcos said..just leave it in, especially in warmer outdoor weather.
yyhayyim is offline
Old 05-05-2009, 04:34 PM
  #184
s.nicholson's Avatar
With a fan the motor will run 10Deg Cels - 20Deg Cels Lower and it will have the natural feel of a drag brake. Without the fan, the punch, braking speed and top speed will increase by around 5%. I think it just depends on the drivers own preference so dont just follow what everyone else runs, try it yourself try with it and get another rotor and try it without the fan. My own preference is without the fan.
One thing to remember is if you pull a fan off make sure you shim the rotor out so it feels the same amount of play as with the fan.
s.nicholson is offline
Old 05-06-2009, 01:18 AM
  #185
scrawl's Avatar
I was hoping someone would be able to explain what's changed between the v1.1 GT and v2 GT.
The product description isn't proving to be very helpful. As an example, "Green power" isn't really explained in any detail.
scrawl is offline
Old 05-09-2009, 06:33 PM
  #186
xraysteve's Avatar
I got the gt pro and ran
a 4.5. It ran very well. I had no trouble with over heating. I have a question about the capacitors. They are a little big and bulky. Is there other ones I can buy that are smaller and still have no trouble running mod?
xraysteve is offline
Old 05-10-2009, 01:29 PM
  #187
Bill-CZ's Avatar
support LCD Professional Program Card esc GT v1.1, it still display connecting to esc? thanks
Bill-CZ is offline
Old 05-10-2009, 05:08 PM
  #188
xraysteve's Avatar
Ok I still would like to know is the other speed passion capacitors that you can buy are better then the stock ones that come with the gt pro v2. Ok next question. I just got the lcd program card. It says to use between 4.5 and 6.5 volt. I have a 2 cell lipo that is 7.4 volt. So can I use my lipo or do I need a extra power source. thanks for the help ahead of time.
Old 05-10-2009, 05:14 PM
  #189
Mike Haynes's Avatar
The SP supercaps are better.
To use the lcd programer, just plug it into the esc, with the esc plugged into a battery, and switch the esc on. The esc will power the programmer.
Mike Haynes is offline
Old 05-10-2009, 06:08 PM
  #190
Pablo Diablo's Avatar
What difference would we feel on track?
Pablo Diablo is offline
Old 05-10-2009, 06:47 PM
  #191
Ditto. Motor has more of everything without fan. I find the heat difference is not much at all. Something I do is use different size fans as a tuning aid. When you don't have a lot of grip running a fan will allow you to use a bigger motor and have more top end with better driveability. I generally run a cut down fan to get the best of both worlds.
Dragonfire is offline
Old 05-10-2009, 08:25 PM
  #192
MaxSp97's Avatar
Originally Posted by Powerlink
I'm on my second grand turismo pro 2.0 .I love this Esc. however I put my car down on the track ..run it a few laps and the darn bottom case half of the ESC is separating from the top and cracking .This has happend to me twice now. Who can I send these ESC's to so they can replace the cases .I bought them two weeks ago ,and have the recepts . The plastic looks very thin and brittle on the bottom half of the ESC's . Thanks Karl
Hi Karl,
Contact Adam, he will take care of it.
Adam Bailey
Technical Sales
[email protected]
www.racing-cars.com
PH: 813-889-9691
SP has the GREATEST Customer Service.
See You in June...
~Cal
MaxSp97 is offline
Old 05-12-2009, 03:55 PM
  #193
kidsid99's Avatar
Trader Rating: 53 (100%+)
Is there anyone that is running a GT 2 LPF with a single cell lipo for 1/12th scale? If so could you please tell me your settings? I need to know if this will work without a booster.
kidsid99 is offline
Old 05-12-2009, 05:44 PM
  #194
Powerlink's Avatar
Originally Posted by MaxSp97
Hi Karl,
Adam Bailey
Technical Sales
[email protected]
www.racing-cars.com
PH: 813-889-9691
See You in June...
~Cal
Thank you Calvin, your a life saver see you at the races
Powerlink is offline
Old 05-12-2009, 07:02 PM
  #195
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I'm running an LPF 2.0 in 12th and WGT with 13.5 and 17.5 motors with a 1 cell lipo.
FWD BL, no reverse
timing 26*
AMTS -9
no lipo cut off
heat protection enabled
6% neutral width
10% drag brake
initial brake set to drag brake.
I am running sp motors with this set up.
HTH
andrewdoherty is offline
