The Speed Passion Thread
#1862
Location: Oreganastan Pacific Wonderland home to Indoor Farming
#1863
How is the new 107 and 110 firmware holding up against the likes of the AE BD, Castle MMP, Tekin v203 ?
#1865
Tech Legend
Adam: I sent this to Shawn but I figure you may know about this too, have you ever seen this before:
This is the programmer you guys sent out to me, do you know how I can get those pixels unstuck? Other than this it works fine though.
A question about profiles, when you switch between them, do you need to reset your radio to your ESC?
#1867
Guys I'm going to run a speed passion v3 11.5
for the first time at titc and was woundering
what gearing it likes
#1868
Don't be afriad to keep gearing up....I always start something (SLOW) so I don't have to fry the speedo/motor within 3 minutes....motor temperature is your best friend here.
#1869
Thanks for that
#1870
Tech Legend
just to clarify, so changing the profile on the programmer also changes the software?
Did you guys get any more LCD programmers in?
#1871
Under BASIC tab, the Profile/Mode You can create 3 different setting and save these 3 settings under only ONE software version (under software tab). On the other term, each SOFTWARE VERSION can have 3 different settings for user to SAVE.
In this case, lets say you are using version 091110STOCK under SOFTWARE VERSION....after uploaded that version of software onto your GT2, you MUST reset and recalibrate your speedo/remote.
Now...you want to change setting, start up the LCD programmer, go to Profile/Mode and choose Mode 0 and do your DRRS AMTS or whatever setting that you want....go to profile and NAME that setting (ie. 13.5 Rubber 01) and hit APPLY and that would save it. Then you can change to Profile/Mode to Mode 1 and do another changes...once they are done, create another name called 13.5 Rubber 02 and hit apply.
To answer your question...changing between Mode 0, mode 1 and mode 2 DOES NOT require radio/speedo recalibration. AS LONG AS they are all under the same SOFTWARE VERSION that you were using prior.
#1873
It gets a bit confusing seeing they call the esc firmware "software" as well.
#1874
Btw...fireware vs software, who incharge of whom? On Speed Passion...its only refer to "Software", not firmware.
#1875
Some bonehead questions:
what is drrs start mode ?
is there somewhere I can go to see how much gearing I should be running and what timing I should be running for each motor ?
