Like Tree3Likes
Tamiya M05 Pro
Old 05-20-2009, 01:56 PM
  #136
Hyde's Avatar
This body will go good on the M05....!
Hyde is offline
Old 05-22-2009, 06:34 PM
  #137
cannon's Avatar
Trader Rating: 35 (100%+)
Interesting reading some of information so far from Tamiya.
The M05 bearing kit comtains 12 1150 bearings !!!! Does this mean going back to 1150 in the wheels?
The rear alloy hub carriers are listed as fitting the M03 as well and will need the 1050 bearings
The front alloy uprights are also listed as fitting the M03 but makes no mention of requiring a 1050 bearing. So would suggest that it will use a 1150 bearing maybe? A bit like the old style alloy upright.
So far a bit confusing. Gives the impression that you will have 1150 bearings on the front and 1050 bearing on the rear if you use the alloy parts
cannon is offline
Old 05-25-2009, 06:02 AM
  #138
In all the pictures I've seen so far of the M-05 Pro, it has got alloy rear uprights, but plastic fronts. And the spec sheets I've seen also make no mention of alloy front uprights, just the rears.
Seems a bit strange that Tamiya would do that with the kit, you'd have thought that alloy fronts (or front & rear) would have been the better option.
Toon is offline
Old 05-25-2009, 06:16 AM
  #139
cannon's Avatar
If you look at my post just in front of yours I mention that they have an alloy front upright
Try part # 54177
cannon is offline
Old 05-25-2009, 06:49 AM
  #140
Sorry for any confusion... I meant the alloy front uprights being included in the kit itself, not as a hop-up you have to buy seperately. The pictures I've seen of the M-05 Pro, presumably showing exactly what it's like once built, only show rear alloy uprights. I would rather have alloy fronts than rears if they are included in the kit (I currently use plastic all round on my M03 though ).
Toon is offline
Old 05-25-2009, 08:30 AM
  #141
chinamonkey7's Avatar
just want to ask, what kind of tires you guys use in the m03, m05, cup racer....... can you show me a list of tire?? thanks
chinamonkey7 is offline
Old 05-25-2009, 10:41 AM
  #142
Hyde's Avatar
Check Here
Try tamiya M-grip tires in the front and S-grip in the rear.
You could use S-grip tires I the front but that tire is pretty soft and might wear out faster. Having a med grip gives you a little more wheel slip but you'll have longer tire life.
ABC slicks and HPI x-pattern seem to work the best. They offer the most grip without signs of wear for months
Hyde is offline
Old 05-25-2009, 12:04 PM
  #143
thanks for the infor
Old 05-25-2009, 12:54 PM
  #144
The best tyres I've used on my M03 are the Team Powers 32R slicks. I've tried Tamiya S-grip/M-grip radials & type-A slicks, but they just give way too much grip roll on my car, even with front & rear inner/outer sidewalls glued. The Powers' give me very little grip roll at all. This is running on carpet though, outdoor running may well be completely different.
I'm currently trying out some Much More 'Sweep' slicks, to see if they perform as well as the Powers' for me.
Toon is offline
Old 05-26-2009, 01:30 PM
  #145
mi2driver's Avatar
most of the drivers where we race are usingthe smaller diameter tyres to stop the grip roll
mi2driver is offline
Old 05-28-2009, 03:13 PM
  #146
RogerHewson's Avatar
Smile Tamiya America M Chassis 6 Hour Enduro
Tamiya America is hosting a 6 hour M chassis enduro at their Aliso Viejo track on July 18th! Here is the link to the rules, entry forum and details. There will be prizes and a good time will be had by all! http://www.tamiyausa.com/articles/fe...article-id=405
RogerHewson is offline
Old 06-03-2009, 04:29 AM
  #147
Let's predict the handling characteristics.
1. weight distributed more evenly, but less weight over front wheels.
2. front shocks laid down substantially from m03
your thoughts?
redbones is offline
Old 06-03-2009, 11:21 AM
  #148
jonest's Avatar
Can't wait for the arrival of the M05!!!
jonest is offline
Old 06-04-2009, 10:45 AM
  #149
Hyde's Avatar
It goes either way. Smaller tires will stop or reduce traction roll but the person with the taller tire will have it in the straight..but real racing is done in the corners
your thoughts?
More easy to drive. And the m03 wasn't hard at all lol
smoother steering. More predictable steering. Not so twitchy and unstable at times.
Better for foam on carpet racing! Low COG with more laid down shocks...it will take a faster sharper turn with high traction carpet racing without flip overs.
I think the steering system is a HUGE plus. And we'll enjoy it more. Isn't a proven fact tho just thoughts
Hyde is offline
Old 06-14-2009, 06:09 AM
  #150
Can't wait for this.
Been watching the mini races and decided that I had to be part of it.
rnd_tang is offline
