Tamiya M05 Pro
#151
m05
from tamiya usa
Tamiya is proud to introduce the release of a new chassis to the very popular M Chassis range, the M-05 PRO chassis kit. The new chassis layout features new servo, receiver,and ESC positions for improved weight distribution and a lower center of gravity. Further-more, a 3-piece tie-rod steering linkage offers sharp cornering performance. This machine handles extremely well on straights and proves its worth with its excellent high-speed cornering ability. Body shells and numerous Option Parts for M-03 chassis machines canbe loaded onto this machine easily.
Full ball bearings.
Length: 299mm, Width: 165mm, Tread: 138mm.
Includes three chassis extension attachment allowing you to make either a short, middle, or long wheelbase chassis car. (Wheelbases: 210mm, 225mm, & 239mm.)
A number of high precision parts such as aluminum rear uprights, aluminum ball connectors, setting spacer, three kinds of springs, high-torque servo saver, and aluminum servo horn are included.
CVA Super Mini Dampers (clear) and TRF short damper springs (soft, medium, hard 2pcs each, white) are included.
Motor and body are not included.
ESC, 2-channel R/C system, battery pack & charger are separately required.
A wide variety of Option Parts are available to further customize your machine.
Full ball bearings.
#154
R/C Tech Elite Member
If the uprights they're using are being transferred directly from the M-03R, then they would have been 10x5. It seems they're maybe using the "other" M-03 upright size though.
This could be to simplify the process of purchasing bearings. It could also be that a larger bearing may be a little more efficient.
Is this for the M-05 only and not the PRO version?
Jim
Jim
#155
m05
m05 aluminum front and rear uprights part numbers are#54177 and #54178. m03r aluminum part numbers are#49441 and#49442. m05 pro comes with aluminum uprights... i wish i can use m03 uprights on m05. i think 1150 bearing are too big for mini. even tc's not using 1150 bearings
#156
MO5 Pro only comes with rear alloy uprights. Alloy front knuckles are not included in the kit and need to be purchased seperately.
Regards,
Calvin.
Regards,
Calvin.
#157
#159
I think there are only 3 things it doesn't come with, the blue screws, the trf shocks and the front aluminum steering knuckles.
#160
I just messaged the dood who posted it, Skitee's right. That would've been so sweet if it at least had the TRF shocks.
I still want one though!
#161
So is it for sure the release day is the 27th? I already paid for mine in full!
#165
