T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 02-20-2011, 12:46 PM
  #7141
I bought yokomo gear diff, but it leaks
What I need to eliminate leak ?
ezh_m5 is offline
Old 02-20-2011, 01:08 PM
  #7142
I recently built two and neither one leaks. Just make sure the two halves are seated on each other evenly when put together and tighten screws in a x pattern a little at a time till tightened. Also I put green slime on the o ring. If you over fill they will most likely leak. If none of that works you could try doubling up on gaskets. Good luck.
JETT is offline
Old 02-20-2011, 01:14 PM
  #7143
Originally Posted by hanulec
you used 44.5mm front shafts, right?
Will get back with you on that. Have to measure.
JETT is offline
Old 02-20-2011, 02:57 PM
  #7144
Originally Posted by mwoods
anyone got these on there car if so any good
http://cgi.ebay.co.uk/3Racing-Sakura...ht_1499wt_1139
yeah ive got them on my photons ( x2 ) they fit nice with a bit of shimming and some grinding of the shaft ...
in my opinion , i reckon the seem to run truer , and smoother ..
done 3 meetings now with no problems ...
but you do need , different size bearings ....
shaun207 is offline
Old 02-20-2011, 03:09 PM
  #7145
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Or you could run the stock plastic ones that I have never ever had a problem with in almost 2 years and they dont add 10 grams to the drive train.
L.Fairtrace is offline
Old 02-20-2011, 09:42 PM
  #7146
+1 For the plastic pulley's.I have 5 sets mounted on different spur gears so I can change spur gears very quickly
mcb-jet is offline
Old 02-20-2011, 11:21 PM
  #7147
the plastic pulley im using now dont run true , ill order another plastic as i dont want to have to buy two bearings just to use the 3racing one
mwoods is offline
Old 02-21-2011, 12:08 AM
  #7148
fair point but i was after the " bling " side of it , but it does seem to run smoother ..
besides that , with my big 5000mah lipo , and all balanced spot on , it was still too light ( minium 1350kg ) even with a normal weight shell !! ...
shaun207 is offline
Old 02-21-2011, 12:23 AM
  #7149
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
but the last place you want to add weight is:
#1 in the drive train
#2 higher than the chassis plate
i agree that the plastic spur holders leave a little to be desired, but once you learn the trick (find the loosest spot w/in the gear mesh, and re-adjust to that point on the spur) to set your mesh correctly it becomes a non-issue.
hanulec is offline
Old 02-21-2011, 12:47 AM
  #7150
But if your car is light you don`t add weight to the highest point of the car and sertanly not to the drivetrain...
chovden is offline
Old 02-21-2011, 05:41 AM
  #7151
Good idea!
JETT is offline
Old 02-21-2011, 08:01 AM
  #7152
hey im running on carpet with foam tires. I see alot of people using gear diffs lately but notice all the old setupsheets say balldiff. I am not a real experienced racer can someone help me out and let me know should I go with gear diffs and if so the spec r's or something else, or just stay with the ball diffs.
Thanks!
gguertin145 is offline
Old 02-21-2011, 08:09 AM
  #7153
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up
Originally Posted by gguertin145
hey im running on carpet with foam tires. Should I go with gear diffs or just stay with the ball diffs??
Thanks!
Ball diffs, front and rear.
Kwikvdub is offline
Old 02-21-2011, 09:43 AM
  #7154
hanulec's Avatar
People are experimenting with gear diffs front/rear/both on carpet -- but I think the average racer is better off w/ a spool/ball diff combo. Outdoors there is no doubt that a rear gear diff is the way to go!
hanulec is offline
Old 02-21-2011, 09:56 AM
  #7155
rcfiend's Avatar
Trader Rating: 42 (100%+)
For those of you that have switched steering bell crank because of breakage, whic one are you using. The Top Alloy Crank or the King Headz available at Amain hobbies.
rcfiend is offline
