Tekin RS/RS PRO on 1s Lipo Q&A >
Old 09-22-2011, 06:44 PM
  #991
Infinite 12th's Avatar
Originally Posted by HarryLeach
They're illegal in every class EXCEPT 1/12 scale.
Seem to save the cars from a bit more damage too, don't have a car getting launched over head high after flipping in a corner and having a mobile ramp drive under it at full speed.
Nice but haven't seen them like at worlds
Are people stop running them
Am I wrong?
Infinite 12th is offline
Old 09-22-2011, 06:50 PM
  #992
HarryLeach's Avatar
Am I wrong?
Guys at the worlds don't usually crash too much.
They're still legal in 1/12, but that doesn't make them required.
HarryLeach is offline
Old 09-22-2011, 06:51 PM
  #993
Mugen10's Avatar
Originally Posted by Buckaroo
We have found that roll over antennas, when used, will most often act as a spring and make the car flop back over again if it gets upset for any reason. Every 12th at my track runs 'em for just that reason.
Does 12th scales roll over?
Mugen10 is offline
Old 09-22-2011, 06:53 PM
  #994
Oh yeah!
AreCee is offline
  #995
RacinJ's Avatar
@All Dudes
Any pics please of booster in a car or receiver packs so I can see how you placed it?
This is the set up I've been running for over a year. Works awesome.
I use a Losi Micro 4 cell NiMh pack. (About $8 - 9) I can use my old charger on it.
I'm a cheap ass.
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-tekin-wiring-diagram.jpg
RacinJ is offline
  #996
HarryLeach's Avatar
Sometimes, usually with driver "help".
Old 09-22-2011, 06:58 PM
  #997
How do you spell traction roll...lol
Old 09-22-2011, 07:38 PM
  #998
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No more rollover antennas anymore
Hence more exercise for turn-marshals
I noticed the transponders also got smaller but yours looks regular
I do run a rollover stick, but when I pack the car in the pit-bag, it is removed.
That is the older personal transpo, saved the new tiny one for the mod car, where is is easy to tuck away.
Attached Thumbnails Tekin RS/RS PRO on 1s Lipo Q&A-5.2il_s.jpg
RedBullFiXX is offline
Old 09-22-2011, 08:11 PM
  #999
That car looks really good by the way
Old 09-23-2011, 06:49 AM
  #1000
AMZ
AMZ's Avatar
I'm a cheap ass.
Interesting , I thought the receiver pack would plug straight into the receiver.
Is there a reason you do it this way?
AMZ is offline
Old 09-23-2011, 07:19 AM
  #1001
HarryLeach's Avatar
Wiring it the way shown allows the whole electrical system to be operated by a single switch.
Old 09-23-2011, 01:33 PM
  #1002
Also Tekin says if you plug a 2 cell lipo directly into the RX it will kill the ESC over time. Needs to be regulated down to 6V. Personally I just run a booster, just plug in and go.
slotracer577 is offline
Old 09-23-2011, 05:48 PM
  #1003
RacinJ's Avatar
This wiring diagram was on this thread a year ago.
They said that wiring into the switch harness puts the receiver pack in series with the main pack. So you can run a 1s, 2s, 6.6v LiFe, 4.8v NiMh or even a single 1.2v NiMh and the most the radio will see is 6.0v from the ESC's BEC circuit.
RacinJ is offline
Old 09-25-2011, 06:35 PM
  #1004
Charlie 13's Avatar
Default Receiver Pack
Today i ran a life receiver pack for the first time, after the 2nd practice session the car died (12th scale 17.5 blinky). A buddy came over and said it was because the tekin switch was on, it needs to be in the off position otherwise it back feeds the motor from the receiver pack. I killed the receiver pack (brand new), shows 1 volt.
What am i missing, nothing for the last few posts about receiver packs mentions this?
Charlie 13 is offline
Old 09-25-2011, 06:52 PM
  #1005
I'm sure your buddy means well but you can leave the Tekin's switch on to use the LVC or leave it off if you have enough discipline to pull off before you over discharge the pack.
You can leave the power wire plugged into the receiver. I and all the other RX pack users with Tekins at my track set it up the same and in two years have not had one failure of a receiver pack or of an ESC unless you count reversing the battery wires when plugging it in.
Check with Tekin and they'll tell you the same thing.
Also from what I understand about LiFe is that they can be discharged much deeper than Lipo. Check to see if you used a LiFe compatible charger because using a Lipo charge profile will overcharge the pack.
AreCee is offline
