Tamiya TRF415
racing
i'm still using my 414X and still kicking butt
lol
but yes would like to try the TA05 MS
lol
lol
lol
Thx for the replies regarding 48 pitch gears. Will prob start off with stock 1st to get rid of the cobwebs then move onto mod later.
most likely there will be a TA05 R... i doubt they use the MS name
Originally Posted by Ballsie
The car comes with NO "bridge" suspension block.
B-XB and XD-B running from the front to the rear - no spares / options included.
There's an "A" block too, I've just found it!
dd aa
just wondring I have seen aa dd AB ect ont the front now what does it do when u use D B or D C pulling the arms in in the ft IE: inboard toe more turn in less out ?
Originally Posted by Barry White
New stick pack chassis with new upper deck.
Hello all, looking for an easy to drive setup for a 415MSX with the yoko diff. rubber tire stock motor high grip carpet..... Also what's good/bad about the DJ suspension system? Good for rubber tire inside? Thanks in advance, Ray
May be a simple answer,
but how do you fit a non bridged suspension mount at the front?
Have anyone tested Titanium Racing spool with delrin outdrives on the standard TRF415 suspension?
I have problem with it, the outdrives seems too short which makes the drivshafts popping out easy. I tried it with the longer MS shafts but those are too long causing lots of chattering. I think it is designed for the MS LW suspension.
Maybe you have to use other suspension blocks/trackwide to use.
hi, anyone have problem with the front titanium cva (hopup) on the MS, with the pin falling out of the cva joint?, the pin is still in place (held by the set screw) but comes out of the hole on the outdrive.....
I've had that problem a couple of years ago on a TA 04 with standard uni's, just make sure the setscrew is tight, and that it's the black set screw that came with the uni, it has a rough textured surface so you don't have to use threadlock
