Tamiya TRF415
hi was wondering if the shocks, u can buy specific parts for it? like just the shaft or the o-rings or the plastic end bits....
Originally Posted by buboy28
ok thanks hope that they will give a very reasonable price for shipping
Originally Posted by Ballsie
I was speaking to Darren at Titanium Racing today and he tells me about using the Pro4 knuckles on the MS / MSX?
Is this fairly simple to do as I've bought the TiR Pro4/415MS CVD's and a set of Pro4 knuckes.
Will they fit directly or will I need to do some trimmming?
Cheers.
Alan
Cheers.
Alan
They fit almost directly, especially if your using the Pro4 axles.
You will need some 10x5 bearings for the hubs, and a 0.7mm shim to place on top of the hub (the hub is lower). Also, they are wider, so place the wheel out further (i countered this by using 4mm hexes, vs 5mm ones I was using on the LWT hubs).
I've got a set mounted on my car at the mo, and really like them (more steering due to changed ackerman, and lower axle height). Just make sure you use the rear most hole on the hub for the steering link.
HiH
Ed
Originally Posted by Jack2
Check ouy my new body on my MSX.........
Nice!
gtb5.5http://www.rctech.net/forum/attachment.php?attachmentid=97610&stc=1
http://www.rctech.net/forum/attachme...id=97611&stc=1
Hi Guys,
My 415 arrived last night, and looking to get a decent setup for this weekends big race. Ill be running double pink/orange double pink Jacos on ozite carpet. Its a flowing track, definately not tight. Its a std 415, looks to have hardened arms, 3mm chassis. Im pretty limited on suspension blocks, from what i could see this morning before running to work, it had 1D 1A, and i think a 1C in the rear. didnt catch the other one. Has a few in the box it came with also. Currently has a centre one way and front one way installed, and im stuck here because the only other option is a spool. Didnt seem to come with a front ball diff. Ill try to make one from the parts it came with, but not sure (didnt come with a manual either). Ill be running a GTB 5.5R, 3800's. Any help to get me sorted would be GREATLY appreciated Any online manual would be a major bonus Im after a consistent setup, something i can drive easily Many thanks guys
-AJ.
-AJ.
pro 4
Originally Posted by TryHard
Hey Ballsie,
HiH
Ed
HiH
Ed
Jack...did you paint that yourself? Awsome work!
John
John
Originally Posted by Customworksking
Tryhard can u hook me up with the part #'s I need to use the pro4 setup Ide like to try it..thanks Kevin
4x 10x5 (or 1050 if you like) bearings (8 if you want to use the rears too)
Axle wise, you can use either
TAM53499 Tamiya Universal Axles (as used in the 414 suspension)
OR
HP75187 PRO4 Universal axles (NOT the MIP CVD ones)
Either of these will be a direct fit to the 46mm dogbones, but with the Tamiya axles, you'll need to use axle spacers to take up the play. These were designed for the std hub, in which the bearings are spaced further apart than on the pro4 hub.
Also, when putting the hubs in, you'll need to use either 0.5 or 0.7mm shim to take up play between the knuckle and c-hub. Place on top, to lower the axle height (which is part of the whole point of using them )
HiH
Ed
John
John
2x HP73507 Front and Rear Hub carriers
OR
HiH
Ed
OR
HiH
Ed
Originally Posted by maxoo
And for the C-hub, do you use the Tamiya part?? or HPI pro4 part???
HiH
Ed
thanks
msx
sup I RAN MY msx tonight for the 1st time with cs27s 19turn with spool
1st I had a push useing A C blocks then went to A D didnt help so I went back to A A no push... now its a bit loose in the rear off power it is new crc carpet but there is some dope down... running A D blocks rear zero hubs 5mm ride 5mm droop Ft&rear the old way to fix was to run cs 22 on the rear but I don't want to do that due to TCS racing the tamiya type A is about the same as a CS27..its just a bit too loose for me any help will do
