Tamiya TRF415
#9871
Originally Posted by BritRacer
OK, it seems i had the TA04 hard front uprights on, are better/worse that the LW C Uprights?
I have some C Uprights, but the current bearings in the Hard uprights dont fit.
What size bearings are designed to go in the LW hubs, Do i need different axles?
thanks
thanks
And the Cv shaft,you should use a longer one then previous arms.Say a 46mm swing shaft and a TB EVO4 wheel axle.Hope this helps.
#9872
Originally Posted by FTD RACING
One thing I noticed on Adam's car was that he doesn't run the 4 chassis posts, does anyone else run their car like that?
#9873
Originally Posted by Ben.C
The LW sus arms are totally different arms altogether.The bearings are way smaller. If memory don't fail me.It should be a 850 bearing(could someone verify).
OK, now that I know which is which, the LW seems to leave huge gaps between the two suspension mounts.
Is this what the MS chassis changes?
If I want to keep the standard chassis, are there parts I should be shimming with, or do I use a lot of 2mm spacers??????
And LASTLY, i am using Kobiachs carpet setup, how should I shim the LW arms??? 0.7mm at the rear will push them waaaaaayyyyyyyy back.
#9874
The LW sus arms are totally different arms altogether.The bearings are way smaller. If memory don't fail me.It should be a 850 bearing(could someone verify)...
#9875
[QUOTE=BritRacer]OK, seems I put the standard arms and assembly on rather than the LW...DOH.
The Shock towers,and main chassis are diff also.The 415 uses a 3mm chassis while the MS uses a 2.5mm one.
Regarding your shimming of wheelbase.I use the setup recammanded in the instruction manual that comes with the LWS arms set.
#9876
Brit racer; If you don't have the LWT manual, try these spacings.
On the front, place 2mm in front of the arm, and 6mm behind (2x3mm).
On the rear place 5mm (2mm+3mm) and 3mm behind the arm.
F.Alonso; the hole in the middle of the std front shock tower is for a 5th body post. Allows you to support the front wheel arches in a roll over/crash, avoiding the nasty spilts that run up them. I'm currently running it whilst racing indoors on a (very) tight indoor carpet track, seems to help when I crash If you want to try it, take a rear bodypost, and mount it with in a similar manner to teh rear ones. Just don't forget to ream another hole in your shell....
HiH
Ed
HiH
Ed
#9877
Do you need to use a different roll bar kit when using the LWT suspension? I wanted to give it a try at Bedworth but the front one just wouldn't fit.
Also, I have noticed that the slop on the back hubs is pretty poor - probably due to the small bearings - what do people do to tighten this up, if anything.
Andrew
Andrew
#9878
HiH
Ed
HiH
Ed
However, after reading another 50 or so pages of this thread last night, I discovered that as I run on carpet, the standard arms are a better option for me.
I plan on running on asphalt in the autumn when its cooler outside, so I will try them then, but I think I will get a MS chassis with more flex and so that I don't mess up my carpet chassis.
THanks again to everyone for the help....
I am slowly but surely getting there!!!
#9879
Thanks, I don't have the manual, I will try that.
415MS - http://www.tamiya.com/english/rc/rcmanual/trf415ms.pdf
415 - http://www.tamiya.com/english/rc/rcmanual/trf415.pdf
415 LWT Suspension Set - http://www.tamiya.com/english/rc/rcm...f415revsus.pdf
#9880
Thanks ballsie! That was a great help.
Would the latest recomendation for capet be? The LW or the standard setup?
#9881
No problem!
I'd recommend the standard suspension - thats what I use.
I have used the LWT setup though and it's still good, but not as good.
#9882
I have been using a mates spare 415MS car and liked it so just got a 415 2nd hand.
the 2nd hand car has 4mm shims under the ball joints on the steering linkage plate, where as everyone at the club I run at uses 1mm spacers.
Can anyone give my any idea as what the increase in spacers has?
#9883
Barry Hughes, running more spacers under the front inner camber link position raise's the front roll centre, allowing the front of the car to roll more, generating more steering. I run between 4-6mm spacers on my car, I like the way it turns in a lot better(asphault) than the way it does with 1-2mm of spacers.
Hope this helps
Hope this helps
