Tamiya TRF415
#9106
When you had it down to bare chassis and put it on a flat surface, did it have a tweak? You can check to make sure that you do not have any extra CA glue blobs on the edges of the chassis. To add to what Jack2 said, also loosen the shock tower screws as well and tighten those last.
#9108
Originally Posted by Mr-s413bt
Heya Guys.
When built to kit specs (stock 415) do u find some play between the arms and the suspension mount?? I used the washers like mention in the manual.
Thanks.
Glenn
Thanks.
Glenn
#9109
how much do the belts move when i go drive, i have only have about 2-5mm of space between some of my wires and the belts, also my batts are like 1mm away is all that ok?
#9111
Yippee , at long last i have my low friction belts , screw kits etc. Now the fun begins .
#9112
I'm trying to get this tapping the batts in (never had to before) and i can't do it, is there a battery strap for this car?
#9113
I think Speedtech RC can help you with that.
#9114
ya, i was wondering cause there are 2 holes already in the chassis that are in the perfect spot for a batt bar, but before i spend money, i'm gonna pratice tapping the batts incause i tried 3 times and on the third time it turned out OK to be honest very good for 3 time total
#9115
#9116
no, there are 2 holes 1 is on the right of the tape hole (rear) and another on the left of the tape hole (front) they are countersunk and look factory to me. Maybe i'll get a pic later
EDIT: you can see them in this pic
#9118
Originally Posted by Burlap
Is that car second hand? Those aren't factory holes. With my 415 being 2nd hand, it had a countersunk put into each of the battery tape holey things (technical name) and I could just screw the XRay brace straight into it.
#9119
i agree with burlap i have both the ms and standard chassis plates and those holes dont appear on either. why not tape the cells? it saves weight and as long as you file the slots a bit the tape shouldnt break.
#9120
Jun Body
Hi guys!, anybody have any pic of Junīs car Running at Reedy race? not chassis, just car with body, anywere!
Thank you
Thank you
