Tamiya TRF415
#9046
Originally Posted by pookat
I also ran the pro module suspnsion at a u.k. track today. Very happy with how it went.
Does anybody know the spring rates for the flourescent springs and the rate for the supplied red spring? Ed?
Fluo red : 6-7 lbs
fluo yellow : 7-8 lbs
fluo blue : 8-9 lbs
#9047
here are a bunch of TRF 415 parts for dirt cheap. most new in package. click on link:
http://www.rctech.net/forum/showthre...23#post1614823
#9048
yup TRF415boy got them down for ya
Went back to ashby today... thought I'd do a bit more testing ahead of next weekend. Put 4 packs through the car, played with gearing, suspension and bodyshells.
I'm pretty much set for the nationals now.
I softened the springs one rate all round (Yellow on F, Fluro Red on R) the car, and put yellow roll bars on. seemed to have more grip, and was even more stable! could happily ride the crubs without the car stepping out, was just awesome.
If anything, had not quite enough initial turn-in, but i can play around with that next weekend, possibly by just changing back to CS22's.....
Fingers crossed for a good time next sunday..
Ed
Ed
#9049
Originally Posted by Nexus
Do not get the DJ suspension if you are running carpet foams.
I test fit a set of GP3300s in my 415 today...they will fit depending on what bars you use. The ones I had just barely touched the belts. With a different type of bar they would fit no problem.
#9050
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by Bad Boys Racing
what bars were you useing, this could be a major problem for me
#9051
i'm running deans and SMCs on some of my packs, he had me worried, thanks for the quick reply
#9052
Tech Legend
If you have your tabs out it will be a breeze.
#9053
thanks, does the car come with 48 or 64 pitch gears?
#9055
Originally Posted by KREATOR1
415 comes with 64 pitch 102t spur
Small correction...hehehe the 415 and other tamiya cars comes with 0.4 module gears. This module is similar to 64p but not identical. If you compare the tamiya spur and the other spurs from Yokomo/Xenon or kawada, the tamiya will be a bit bigger.
Cheers
#9056
can i use 64 pitch gears or get a 48 pitch spur?
#9057
Originally Posted by viper1
Hi Kreator,
Cheers
Cheers
I think they work fine with it.
#9058
Ok seeing as some of you guys are heading to the Ashby National i need alittle setup advice for a STD 415 running both one-ways in the stock class ? Dont think my order from speedtech will be here in time so the car will be left in standard spec.
Just got my car come through this morning that i brought on ebay and it all looks in very good condition , not even a scratch on the chassis as it was only raced indoors on carpet. Should help save on some built time for this weekend.
#9059
Try Blue springs on the front, with yellow roll bars, and yellow and yellow on the rear. Good place to start. Rest of the car as per instructions. (Although remove the spacers under the rear suspension blocks).
Shocks wise, 40 or 50wt oil with 2hole pistons (I'm personally using 40wt oil with 3 hole pistons).
Make sure you run a decent amount of droop thought, with a decent ride height (say 5.5 - 6mm)...bumpy track needs it.
If you get stuck during the day, come over and say Hi, I'll be happy to help, I'l be pitting with a few guys who are also running 415's (Scho and TRF415boy... although they don't know that yet... )
HiH
Ed
HiH
Ed
#9060
I just saw a picture of the Ashby track online, very impressive. I've always liked a setup like Tryhard has described for my Tamiya cars for Stock Racing. For Modified, I tend to find a more even setup across the car works better, so the front and rear are similiar. Just my views so far with them.
