Tamiya TRF415
#9061
questions, why on earth do you run a one way on the belt shafty thingy, or a center diff, to me it makes more sence to run it so that the same power goes to the front and back diffs (or front one way) at the same time/rate
Tryhard, i was on your site and was wondering if the gear ratio chart is for a stock 415? Does the stock 415 have 35 tooth pullies, 16 tooth centre pulley?
#9062
The 415 was awesome during this weekend's Reedy Race...it was far better than the nut behind the wheel Here's a few photo's that my brother took during the weekend. Enjoy!
#9063
#9064
Originally Posted by TryHard
Try Blue springs on the front, with yellow roll bars, and yellow and yellow on the rear. Good place to start. Rest of the car as per instructions. (Although remove the spacers under the rear suspension blocks).
Shocks wise, 40 or 50wt oil with 2hole pistons (I'm personally using 40wt oil with 3 hole pistons).
Make sure you run a decent amount of droop thought, with a decent ride height (say 5.5 - 6mm)...bumpy track needs it.
If you get stuck during the day, come over and say Hi, I'll be happy to help, I'l be pitting with a few guys who are also running 415's (Scho and TRF415boy... although they don't know that yet... )
HiH
Ed
HiH
Ed
What time we going to MC'ds?
#9067
So Rod is this a new car or just new parts that fit onto a 415 and if so were can I get them
#9068
Errr...I don't know of production details and what not. I ran a "standard" 415MS with the Promodule Rear. It worked very well. The other guys built their cars like a day or two before and the first round of practice was the maiden voyage of the new cars.
#9069
I only wish MSX bulkhead won't let us wait as long as DJ arm did (last World to May, that's a longggg time... )
#9071
get some atlas diff covers or make your own.
The main reason the diff becomes gritty is casue of the dirt that gets inside. Can do loads of runs on my diff before it needs a rebuild, since I put the homemade covers on.
Baring that, try ceramic diff balls too (any 3mm ones) will make the diff smoother.
HiH
Ed
HiH
Ed
#9073
Heya Guys.
Well i have finished building my 415!! All i need now is to make up a battery strap and i am all done.
One thing, i built the kit as per instructions, i was wondering if there was anyway to tighten the rear belt???
Also any set up tips for smooth asphalt?? Gearing for a 12x2 on this largeish track?
Thanks.
Glenn
Thanks.
Glenn
#9074
Ran my MS today with the DJ rear end, big thanks to ed for the base setup. Got it lapping very nice from the start, the only slight problem was the rear wanting to come round as i exited the tighter corners if anyone can shed any light on that.
#9075
Originally Posted by Mr-s413bt
Heya Guys.
Thanks.
Glenn
Thanks.
Glenn
G'day, if you want to tighten the rear belt up you have to move the plastic bearing holder around a few notches that supports the rear diff, I'm pretty sure you have to turn it anti-clockwise.
~Jack
