Tamiya TRF415
Originally Posted by rampal
nope... either one or the other... seems it needs to be the 98004249.... anyway, they look the same, what is the difference?
thanks
al
thanks
al
HiH
Ed
I was wondering what the difference between running a center one way pulley and a direct drive center pulley on carpet is. Which is better? Why? Thanks
Hmm stickpack MSXX chassis is coming. Wonder if the Orion 4800 will fit for MRE/MSXX now?
Originally Posted by TryHard
Difference is the bearing spacing is different. Also the rear diff is on the left on the TA05, and the right on the 415.
HiH
Ed
HiH
Ed
anyway, I've been toying with the idea of a front diff... there's no way to put the rear diff in the front... Is there any alternative?
thanks again,
al
yeah, I've checked on mine (with the plastic ones) and realise that even the screw is shorter...
thanks again,
al
thanks again,
al
HiH
Ed
TryHard: thanks a lot for sharing your knowledge....
anyway, other quickie... do you use threadlock anywhere in the car (bulkheads, suspension blocks)?? I have had to use some in the past on my mission to get the topdeck secure, so I wonder if someone also use it on the 415 as well....
cheers,
cheers,
cheers,
cheers,
Obviously a check of all the screws should be a regular maintence thing though.
HiH
Ed
I've only used thread lock on kingpins into the front upright, when they are the RC Square aluminium type. Otherwise I leave things as normal.
I only ever use threadlock on the grub screws in the driveshafts and the screws on the front spool pulley
Charles
Charles
I only use threadlock on universal shaft.
Charles
Charles
I never use thread lock, just tighten them screws like a mad man
Novak GTB Profile & Gearing
Need help.
Just finished installing my Novak GTB & 13.5R BL motor yesterday on my TRF415 MRE.
Need to know what profile do I use & proper gearing (default profile is set a #1). My 415 MRE uses Xenon 102T 64P spurgear with 38T 64P pinion gear = 6.04 final gear ratio.
Would that be a suitable gear ratio on a med-size track?
Any suggestions will help.
Thanks.
Thanks.
Anyone do the TA05 gear and spool conversion on the TRF415MS ???
wanted to know if its worth the effort.
Found the info here http://www.thard.co.uk/tips/
