Tamiya TRF415
Originally Posted by razzor
Anyone do the TA05 gear and spool conversion on the TRF415MS ???
wanted to know if its worth the effort.
Found the info here http://www.thard.co.uk/tips/
For the front and rear pulleys, either follow the advice on the site, or buy the MRE front spool (which requires no modifications to fit the pulleys).
TAM3454395 MRE Front spool
TAM9804267 Drive cup sleves
TAM9804268 Delrin Drive cups
For the centre pulley, just use the parts that come standard with the MRE, as I feel this is a better option. Parts required
TAM345395 Direct Centre Shaft
TAM51213 16T plastic pulley
TAM50589 5mm E-ring
and thats it... all other parts required should be on your 415 anyway.
Having looked at that link again, man, I need too update that page!
HiH
Ed
Originally Posted by JRRobiso
Need help.
Just finished installing my Novak GTB & 13.5R BL motor yesterday on my TRF415 MRE.
Need to know what profile do I use & proper gearing (default profile is set a #1). My 415 MRE uses Xenon 102T 64P spurgear with 38T 64P pinion gear = 6.04 final gear ratio.
Would that be a suitable gear ratio on a med-size track?
Any suggestions will help.
Thanks.
Thanks.
i would probably start around a 5.5, and see how the temps go and adjust from there.
hope that helps...
I'm debuting my MRE this weekend on a asphalt track, 100' straight with rubber tires, very flowy layout. What would be a good starting point for a pinion gear with 102T spur for stock (monster) and 19T Chamleon motors.
Many thanks for any input!
whats up alex? i am pleased to hear you guys are comin to jackson. its gonna be a great weekend bro. i think im gonna start with a 34 tooth pinion for this track. sounds in the ballpark about a 30mm rollout. we will tune when we get there. see you sunday bro.
MY 415 MSX/MRE -- JUST LISTED UP FOR SALE
HEY GUY'S .... I HATE TO DO THIS BUT.... MY 415 MSX/MRE -- JUST LISTED UP FOR SALE HERE...http://www.rctech.net/forum/showthre...20#post3233720
Hi, anyone want to sell TRF 415msx alum. rear uprights my alum. rear uprights has bend and lower deck 2.5mm for 415msx. PM me.
WOW!!............. What a great day of racing at Jackson Raceway in NJ. The traction was real good and the MSX was simply dialed. Thanks Craig for the input on gearing. It was Big Fun in the pits.
Hope to go back real soon. That place is just simply awesome!! .................. And BTW, these cars are only going to get better.
See you soon Bro!
hell yeah alex! what a great time brother. team tamiya in full force baby. as usual your driving was stellar. wish i coulda been in the a main with ya. but i'll take a b main tq and win for the first time out i cant wait to go back. what a day!!! im gonna wrench a little more on the msx so i can rock the 22 laps next weekend. see ya soon bro.
Indoor carpet setup
Can someone help me with an setup sheet of marc rheinard for indoor?
like LRP TCM 06/DHI 07? etc
Arjen
Arjen
guys, can i use the 415 lightweight front one way cup joint (53704) with the MRE front one way housing (53947) thanks
Hoy Buboy, musta na. The answer to your question is that it requires item# 53451 TA04 Front One-Way Joint Set (according to Tamiya USA).
ok lang po maraming salamat sooooooooo i really have to buy that item i thought it might work since it fits the MRE one way housing wishful thinking
new to the 415 scene i thought i would by an mre....
lovely car but themovement on the axles is horrendous... any hints or should i put up with it
