Tamiya TRF415
R/C Tech Elite Member
I'm doing the same but with an MRE chassis (same front bumper, the MSXX uses the Evo5 and is 2mm not 2.5 which would give me too much flex) stellamodels.net had both in stock.
Guys please take into concideration when buying the MRE vs MSXX that the MSXX has 2mm chassis that are more narrow at the back & front end.
The MRE has 2,5 mm chassis that are wider and stiffer.
what to chose will be dependent on track/surface.
Rubber/carpet im going for the MSXX
no problems with precision .. ordered an mre from then two weeks agon.. arrived in uk 4 days laters, its built and ready to go.
should have bought an air duct thou
Originally Posted by Burlap
I thought when you wanted to race on carpet that you want a stiff chassis?
Regards
Ed
I also considered durability, surely more is better for that, and the way I drive......
2.5 was a no brainer
For carpet I usually just switch the front to a ball diff (from a one way) and it's fairly right.
running on lowgrip carpet with rubber, you need the flex.
Originally Posted by TryHard
I wouldn't worry too much... Precision are th eguys who I ordered my replacement MRE chassis from last year (after it got nailed against the armco at west london ), arrived in good time, with everything else in the box.
Seems every once in a while an order slips through...
Ed
Ed
hello guys
hows this car
is it ok for the 540 class
thanks
minnesh
hows this car
thanks
minnesh
Originally Posted by TRF415boy
Funny it must be me then, i ordered twice from them and I had missing items both times... I'm not the only one it happened to though. Plus they didn't reply to my email asking them to send the missing parts...
well, I've always said your special...
its gotta go if anyone is interested....
Mark, I'm interested, how much??
http://www.rctech.net/forum/showthre...39#post3252539
