Tamiya TRF415
Originally Posted by TRFwhitey
hey guys, just came off a sucessful race weekend. With the combination of the new akerman change and new parma 53mm rim tires i was able to give bakker a run for his money at our canadian challenge race. I thought i would include sum pics here so people can give it a shot. This is the single most effective change i have made since ive started running this car. Its worth the grinding!
First pic shows steering links swept back to reduce akerman
Second pic shows upclose the flipped steering rack and bulkhead material removed for clearence.
Third pic shows how we use a 414m belt instead of the narrower 415 belt to keep it from slipping during foam MOD.
If anyone is interested in my setup from this race lemme know.
Never mind. I fixed it.It was a shock ball post spacer problem
does that mod work well on asphalt too? or just carpet?
-ling
corey,
is that the 4mm chassis as well? also i noticed the top deck is countersunk. is that a thicker top deck also and if so how thick? thanxs i always seem to struggle on carpet with my msx and i am eager to try your setup.
Originally Posted by JRRobiso
Thanks. Post the pics when able. Later.
Originally Posted by xtrememadness
corey,
thanx trfracer. i will have to get a hold of some carbon fiber
R/C Tech Elite Member
Originally Posted by Leester
Hello everyone.
I am putting a DJ Pro Module Suspension on my 415 and the left rear blue hub is bound up and is not swiviling smoothly as the right rear. The right rear pin screws in smoothly with no effort the the left is really hard to screw in.
Any suggestions?
-Lee
Any suggestions?
-Lee
Originally Posted by TRF415boy
I don't know why you'd want to buy this though if you got a MSXX since it already comes with it in the kit.
Originally Posted by Racing4Evo
Are you sure? It didn't come with my car. And if it did, it would also have to come with the MRE direct pulley or the aluminum one which weren't included in my kit either.
Originally Posted by sohlman
Here's a top view of my MRE's electronics. I hope it helps. I still need to shorten some wires.
Again, thanks.
set up help
can anybody help me with setup for my msx for the tcs race at memphis it on aspahlt any help please new to this
re
Yes i did run a custom 3mm upperdeck, it was made by a good friend from muchmore racing. You can get the same feel with using two of the stock decks glued/screwed together. As for the damper stay, its the stock piece that came with the car.
The mod i made to the car reduces akerman, which takes the "inside tire scrubbing" effect away mid corner making it smoother and easier to drive. For asphalt more akerman is better but for foam you must decrease it or the car will be very inconsistent. The difference is night and day...trust me
I will be postin my exact setup form the weekend very shortly.
if anyone is interested heres a video sumone shot of the modified A-main at fastcats..
Part 1: http://www.youtube.com/watch?v=krsMRdhWPXs
Part 2: http://www.youtube.com/watch?v=SMmKEDpwjEs
RE: set-up
Good luck in Memphis!
