SMC 40C+  C-Max 7.4V Hardcase Lipos >
Old 01-25-2009, 07:47 PM
  #226
Company Representative
Danny/SMC's Avatar
So the Orion charger has voltage sensing leads ? If it does that is good as you should attach near the power leads to limit resistance as higher resistance will make the charger kick into CV mode earlier which extends the charge time.
Danny/SMC is offline
Old 01-25-2009, 09:50 PM
  #227
hello. sorry to intrude. very new to serious RC and to lipos..
curious.
i currently own an orion 2400 lipo and have a dynamite lipo charger.
it says that it charges 2-4 cell lipos and has charge rates of 500ma, 1000ma and 2000ma
if i were to buy this smc pack
5000mAh 28c 7.4v Lipo
https://www.ssl-stormerhobbies.com/c...&pn=SMC5028LDR
would my charger work for it?
if so, what mA would i charge it at?
sorry if this is a dumb question. i dont really understand anything about 20c or 40c or mA's or anything.
im guessing that more mAh and more C's are better but
this one is out of stock
5200mAh Lipo Battery, 7.4v 40C
https://www.ssl-stormerhobbies.com/c...s&pn=SMC5240CM
macscac is offline
Old 01-25-2009, 10:03 PM
  #228
drperry's Avatar
With your charger, you'd charge it at 2000mAh...
Or 2 amps.
LiPo's can safely charge at 1C which is 5 amps on the 5000mAh battery.
The formula is like this: C x mAh / 1000 = current rating
drperry is offline
Old 01-25-2009, 10:12 PM
  #229
Team STPN's Avatar
curious.
Contact Billy at Speedworld in Roseville, Calif. he has new SMC packs. I got my new pack for the weekend race and it sure does add lots of punch and power. Thanks SMC!!!
http://www.speedworldraceway.com/Page.cfm
Team STPN is offline
Old 01-25-2009, 10:45 PM
  #230
Or 2 amps.
so that means that ill be charging the lipo at less than half of what i could be charging it with?
therefore taking twice as long to charge it?
how long should it take to charge a 5000mAh at 1c?
macscac is offline
Old 01-25-2009, 10:49 PM
  #231
drperry's Avatar
5/2 = 2.5 hours
1C will take 1 hour to charge the battery.
Using your charger it's the 2.5 hour charge...
drperry is offline
Old 01-25-2009, 10:57 PM
  #232
then that means i need a better charger.
what kind of run times do you typically get with these new packs?
im using a castle sidewinder 5700
longer than 10min?
macscac is offline
Old 01-25-2009, 11:05 PM
  #233
drperry's Avatar
You don't need a better charger... But you'll likely want one
As for run times... I can't say... I'm using POS Elite packs, and they don't seem to dump early
drperry is offline
Old 01-25-2009, 11:09 PM
  #234
this will charge at 5amps?
and appears that it will also charge our stick pack 3400 old style batteries we drift with?
good charger?
Venom Pro Battery Charger (DC) for NiCD/NiMH/Lipo/Li-Ion/PB/LIFE
https://www.ssl-stormerhobbies.com/c...=ns&pn=VEN0656
macscac is offline
Old 01-25-2009, 11:35 PM
  #235
drperry's Avatar
It'll charge at 5 amps, yes.
It will also charge pretty much any other battery you have
I've heard bad things about the built in LiPo balancer, though. As long as you use a separate balancer you'll be fine.
drperry is offline
Old 01-25-2009, 11:45 PM
  #236
espresso1967's Avatar
Trader Rating: 18 (100%+)
I use the Hyperion EOSO606i and comes in ac/dc and or charge from your car battery for field use when no power available.
This will charge and balance your lipo without a problem. Been using it for a year now and no problems.
http://www.maxamps.com/EOS0606i-AC-DC.htm
espresso1967 is offline
Old 01-26-2009, 05:21 AM
  #237
cliferton's Avatar
Trader Rating: 21 (100%+)
I assume they are sensor leads. the charger has the main + and - wires comming out of the charger, and then each lead has a smaller wire that ran with the bigger one and they were both attached to the clips at the end. I hooked the balancer up to the + - leads and disattached the smaller wirres. the smaller wires have now been attached on the output end of the balancers +- wires. did I do this right?
cliferton is offline
Old 01-26-2009, 04:05 PM
  #238
Registered User
Hey Danny
Thats great! If SMC decides to make 1/8 LiPo's in 139mm. That way I
Don't have to modify my New RC8 conversion kit.
Ryan
AE_Freak is offline
Old 01-26-2009, 08:06 PM
  #239
mojoman's Avatar
Hey Danny,
A couple of questions on the 4500 EFRA pack. Are you still going to submit it to ROAR for approval? I'd like to know so I can run them at the Nats in October. Second are the EFRA packs going to use the new chemicals mentioned in the first part of this thread that increase the average voltage?
Good Luck to the SMC camp in Florida,
Casey
mojoman is offline
Old 01-28-2009, 09:02 AM
  #240
Core Creations's Avatar
Trader Rating: 108 (100%+)
Anyone know where these are in stock?
Core Creations is offline
