Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 01-11-2018, 03:21 PM
  #9571
Originally Posted by howardcano
I do the same as jdawg81, with balldriver, no L-wrench. I use cap head screws so I can use a larger balldriver to lessen the chances of stripping the head.
It also helps to grind a little off the OD of the bottom screw head. Some of them can be a tight fit; there isn't much clearance.
That’s a great idea on the socket head cap screws instead of the button ones!
I’m assuming neither of you have the latest version of the motor mount?
RollingChicane2 is offline
Old 01-11-2018, 04:28 PM
  #9572
howardcano's Avatar
Trader Rating: 37 (100%+)
I'm guessing no for me. All of my cars were purchased used, and all have the same mount.
howardcano is offline
Old 01-11-2018, 04:43 PM
  #9573
The last generation motor mount is excellent. It is a two piece design that allows you to mount the motor to an aluminum piece and then that piece will slide on a mount that is bolted to the chassis that has a set screw to allow ultra-fine adjustment of the mesh and when you have it where you want it, you tighten two screws perpendicular to the motor to bolt the two pieces together. No more difficulty setting mesh or tightening of screws.
That explanation was probably terrible....sorry.
I have an Evo 2 that is the most recent design with a lot of other options. I run it in VTA and it’s phenomenal.
Old 01-11-2018, 06:53 PM
  #9574
Trader Rating: 38 (92%+)
What’s ur setup for vta
Rcforlife13 is offline
Old 01-18-2018, 03:12 AM
  #9575
Hey folks
I'm running 17.5T evo 2 with alum chassis and carbon top deck. Are folks also running the center spine stiffener when also running top deck or removing it?
WagwanBumba is offline
Old 01-19-2018, 09:08 AM
  #9576
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by WagwanBumba
Hey folks
you need to run the AM33 spines
hanulec is offline
Old 05-22-2018, 05:24 AM
  #9577
jlfx car audio's Avatar
Funny the last msg in this area is about the am33 which is what I'm looking for to buuld my first shaft car .
Anyone got a spare am30/33-5 ?
jlfx car audio is offline
Old 06-19-2018, 04:14 AM
  #9578
Hi engineers and folks,
Will A700-EvoIIC be produced on request? It cannot be back-ordered on the websites.
I heard that ST13 and ST14 will be discontinued and must change to IFJ and IRJ. Is it true? I think my 2 Ball Diffs will be useless if those bones are unavailable.
ricekwan is offline
Old 06-20-2018, 05:33 AM
  #9579
!Mad Max!'s Avatar
Hi ricekwan,
For A700-EvoIIC you can ask via the Support Email from Awesomatix, or your local distributor.
ST13 and ST14 is discontinued/replaced with IFJ and IRJ at Awesomatix.
But ST13 and ST14 can be still available at some Distributors.
A700-AT03M is suitable for the use of IFJ.
A700-GD2 is suitable for the use of IRJ.
What are the advantage of Ball Diffs for A700 over the Gear Diff in your Opinion ? And in which Class do you run with the BD1 Ball Diff ?
Regards, Max
!Mad Max! is offline
Old 06-24-2018, 12:01 AM
  #9580
Hi Max!
Thanks to your help. I like the ball diff since it is a breakthrough to have diff oil in it. It is so smooth that I feel it helps on corner exit, compared with GD1. However it has an issue of oil leak at the case (AT01/AT02). Will try to get GD2. I run modified with X22 10.5T or X20 8.5T.
I have a mod on the RFG to let it float more. It helps me a lot on the real grip. Any other mods to share with us?
ricekwan is offline
Old 06-26-2018, 07:02 AM
  #9581
whats the internal ration of a evo2 car ? just to clarify.
i just find it odd im running a 5.1 fdr (figuring @ a 2.09 internal) with a 25.5 on a larger fast layout track and turning the fastest laps with it
Old 06-26-2018, 08:43 AM
  #9582
chiefj48's Avatar
2.08 internal
chiefj48 is offline
Old 10-03-2018, 07:38 AM
  #9583
ZeroDown7169's Avatar
Trader Rating: 72 (100%+)
I was wondering if you guys knew of any up to date setups for a 700EVO II on this black rug? I know there's some on petric rc, but they're all old "like the car I understand", just seeing if there's any new ones for a vta car out there that you may know of, or should I just use some of the 800's setup sheets as far as dampener and spring rates and roll centers? It's been awhile since I've raced them, I took a break from racing, and I'm looking to use my old cars again. Any other tips or tricks would be greatly appreciated too! Thanks in advance!
ZeroDown7169 is offline
Old 10-03-2018, 11:42 AM
  #9584
geeunit1014's Avatar
Trader Rating: 14 (100%+)
I do not know of any. I would start with my 2015 carpet nats setup as that was very hi grip gray carpet.
ZeroDown7169 likes this.
geeunit1014 is offline
Old 10-04-2018, 06:39 AM
  #9585
Default Setup
i run a carbon car that updated by copying the chassis to the 800x and sway bar holders and I use almost the same settings as the new car and it seems very close . The only thing I’m working on is the diff action
john holmes 69 is offline
