TAMIYA F103 RM
Old 02-16-2009, 03:14 PM
  #1531
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
If anyone one is interested in a F103RM, my hobby shop has one in stock. Im not sure what body it is, I can check if you'd like though. If you are interested, let me know.
SerpentCT4S is offline
Old 02-16-2009, 03:16 PM
  #1532
portyansky's Avatar
Trader Rating: 54 (100%+)
My lhs has one of each body style in stock of the f103rm
portyansky is offline
Old 02-16-2009, 03:50 PM
  #1533
silverhkswrx's Avatar
any of you guys actually done the conversionb yet? i am in the process of it as we speak. i am waiting on the rear axle and front swing arm set from rcmart.
3 things needed...
3Racing (#F103RM-10) Front Suspension For F103RM USD$15.50
3Racing (#F103RM-09) Knuckle Arms For F103RM USD$11.50
3Racing (#F103RM-01/LB) Differential Housing For F103RM USD$17.90
F103GT plus $50 shipped.
this is all that you will need to convert a F103GT to a F1 racer.
misc items incluse body and wings, but no chassis, lower deck, upper etc are required.
there are a few things you need to take into consideration.
1) F103GT kingpins are longer and hold at thte top and bottom keeping the top control arm attatched. if you go with a f103lm pingpin, it is much shorter. and does not connect at the top causing the top control arm to become detatched. the 3 racing arm setdoes 3 things, 1) it connects top and bottom so you can use F103GT on LM, LM on GT w/ no issues. 2) it can adjust castor. 3) you can adjust camber.
**this is the ONLY part that will allow you to adjust camber on this car!
2) the F103LM knuckle has a cylindrical portion that allows the use for a bearing or bushing. if you try this on the GT, it wont fit, will wobble and be horrible to drive on.
3) the Hexes are much larger on the F103LM than the GT. that is why the rear wheels wont fit. the only way to fix this is to get the LM rear axle set.
it is not cheaper to buy an LM, you will end up hopping up the LM anyways with these parts.
If you have a GT convert it, if you have none, Get a LM.
silverhkswrx is offline
Old 02-16-2009, 05:33 PM
  #1534
Anyone know what tires compounds come with teh 15th anniv kit ? I have looked everywhere and nobody lists what they are . Soft , med. ? Also does anyone true thses down for racing ? and is that allowed for TCS ?
mikpiz is offline
Old 02-16-2009, 05:58 PM
  #1535
414MPH's Avatar
Originally Posted by Turbonium
Actually, there is another newer RM kit, its this one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXWCP2&P=7
it shows on order, but who knows if it will come in. in HK, they tell me its already been discontinued, but there might be some left somewhere...
Hey Wes, that's the:
84032 Check your local hobby store. L body
414MPH is offline
Old 02-16-2009, 07:37 PM
  #1536
idwurks's Avatar
D Drive Sport just released a new body by Tech - does anyone have any experience with it?
Looks pretty good aside from the bland nose. I really don't like INTEGRATED nose cones. I am still trying to find the best body and I think the best one is still the Chevron IMO.
What do you guys think? Only $35 with Tech wings!
http://d-drivesportsenglish.com/inde...roducts_id=414
idwurks is offline
Old 02-16-2009, 07:40 PM
  #1537
i am almost positive med front and soft rear. and i think all tamiya tires are allowed in TCS.
Old 02-16-2009, 08:20 PM
  #1538
I know they are all allowed , But are you allowed to cut them down ? I would like to take about 4mm overall dia out of these .
mikpiz is offline
Old 02-16-2009, 08:24 PM
  #1539
Turbonium's Avatar
Trader Rating: 27 (100%+)
tis true... but its also one of the ones i was told by Champ that it was discontinued. i ordered the last R at speedtech, should be here this week.
can anyone confirm what that above RM kit comes with? the info says the height adjustable pod, but how much alloy is actually in that kit? id like to have one of those as well, i think.
Turbonium is offline
Old 02-16-2009, 08:54 PM
  #1540
mild seven's Avatar
Trader Rating: 63 (100%+)
There isnt much alloy in the RM kit at all really. mostly plastic and fibre glass.
mild seven is offline
Old 02-17-2009, 04:44 AM
  #1541
portyansky's Avatar
Whats the best tire compound to run on indoor carpet (Ozite).
What compounds comes in the RM kit?
When I installed the tires I used the supplied 2-way tape. I should be able to remove the foam and save the rims, right?
Old 02-17-2009, 06:53 AM
  #1542
Core Creations's Avatar
Trader Rating: 108 (100%+)
The 84032 comes with the "L" type high nose body/wing set. This is to my knowledge not discontinued.
The 84031 comes with the "T" type low downforce body and is discontinued.
The 49498 kit was the "M" body kit and being a "4" or limited is also discontinued.
Core Creations is offline
Old 02-17-2009, 06:56 AM
  #1543
liljohn1064's Avatar
Trader Rating: 17 (100%+)
the RM comes with medium rears and soft fronts. If the ozite is real high grip and abrasive, switch to mediums or hards. The soft fronts stick real nice until they wear out though. The rear tires showed virtually no wear.
liljohn1064 is offline
Old 02-17-2009, 07:08 AM
  #1544
portyansky's Avatar
You da man!
Old 02-17-2009, 09:13 AM
  #1545
is that the rule of thumb with foamies? abrasive= stiffer foam to make the tires last longer?
i run on a non-prepped surface that is pretty smooth.
