TAMIYA F103 RM
#1383
If I can remember, soft to hard. Silver, Gold , Black
BP/ Robk, Thanks for the tonnes of info. Will be sticking to the PC @ work digesting all that info. Will try it out when the Tamiya season starts!
#1384
#1386
You need a new chassis, rear drive pod (all the parts from the spur gear and out + the other side), you need the RM's steering knuckles, I may missd out a few. You still need an F1 body 7 tires.
I think getting the RM kit would be an overall better deal as you get new parts too.
#1387
Don't think it will be that cheaper to convert to a RM.
Send an email to RC Champ Adviser for a quote. You won't be disappointed.
#1388
#1389
I'm thinking of others as I write this. I just handed out my last spare pod assembly to a destroyed left side pod. I've switched to the 3 Racing pod assembly, aluminum on all 4 sides because of the one I broke personally.
Is anyone running some sort of washer or shim to protect the ride height adjusters and rear pods? We've lost 6 battles with the PVC at our track so far as the bearings just get punched right through the side of the pod. I'm tempted to take a thin fender washer slightly bigger than the ride height adjusters, make sure the diameter is 6 mm and put them in there on both sides. I think it would help distribute the blow the pod would take to the thicker plastic of the pod side.
John
John
#1390
Foam Tire Part Numbers
Anyone have a list\part numbers for all the available Tamiya foam F1 tires?
Also, do any companies make an arbor to true these tires?
#1391
you have:
Kit foams F/R
HBR Softs F/R
HBR Mediums F/R
and then the premounts that come with the R F/R
As far as the arbor goes:
Model: 3023-070
Shipping Weight: 0.18lbs
8 Units in Stock
Manufactured by: Eagle
Thats from the DDrive website
#1392
John,
I saw some aluminium ride height adjusters from 3Racing on RCMart.
Kevin
Kevin
John
John
