Like Tree5Likes
Tamiya TB-03
Old 01-11-2011, 03:55 AM
  #1861
A question about Spool and shims.
According to the supplied intructions the Tamiya Spool requires four 10x0.3mm shims.
Unfortunately they are not supplied in the package.
Can I use six 12x0.1mm shims instead of the four 10x0.3mm shims recommneded in the manual?
Cheers everyone.
tdunster is offline
Old 01-11-2011, 07:56 AM
  #1862
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Cheers everyone.
Not sure how they will work. If they are 12x15, it should be fine.
That amount of shims is a recommendation of where to start. Shim it tight yet with minimal play.
Racecrafter is offline
Old 01-11-2011, 08:30 AM
  #1863
Thanks.
I meant to say 12 10x0.1mm shims.
tdunster is offline
Old 01-15-2011, 11:13 PM
  #1864
SoCalGuy's Avatar
Hey Guys,
Been running Buggies for a while now, but decided to pull my Tb-03 off the shelf. I plan on rebuilding the shocks this weekend, but can't for the life of me remember the correct weight oil to use for the TRF shocks. I know it depends on a lot of variables, but what would be a good starting point (front and rear)? Any spring recommendations would also be appreciated
Thanks,
SoCal
SoCalGuy is offline
Old 01-23-2011, 01:48 AM
  #1865
40wt is a good starting point with the TB-03 chassis.
I prefer to use a slightly heavier spring on the front and a medium spring on the rear.
This tends to produce a car that understeers / pushes especially when running a front spool.
I find this sort of a setup good because it's very predictable.
However, on a longer / flowing circuit it's probabably not optimal.
cheers.
tdunster is offline
Old 01-23-2011, 05:39 AM
  #1866
fantapants22's Avatar
cheers.
+1 i definitely agree with that, stop the car from spinning out
fantapants22 is offline
Old 01-23-2011, 10:51 AM
  #1867
Blueman Austria's Avatar
Originally Posted by Shqizy
Hi guys,
This tread seems to be almost dead, I still want to post my newest mod to tb-03 Diff :
I fitted new 12-3/32 Ball Diff gear of TRF502x !
upper tb-03 gear , lower TRF502x gear
finished Diff:
It feels really smooth and moreover now it can stand 13.5 with boost!
You need:
Tamiya 51438 TRF592x Ball Differential Gear Diff
12pc 3/32 or 2.4mm Diff Balls
--> file about 0.5 mm off of the end of the shaft from shorter diff joint
--> don't use the 0.5mm shim between the 850 bearings
have fun!
Looks like my Ev05 getting an upgrade "asap".
This sounds realy good!
Anybody know a good (cheep) source for ceramic 2,4mm diff balls?
Anyone other tried this modd already? What about the shimming of the diff?
Greetz Blueman
Blueman Austria is offline
Old 01-23-2011, 12:21 PM
  #1868
Greetz Blueman
Hello,
I'm from Austria too and I've used this mod now for a while - on both tb03 & EV05MS.
I don't know exactly the outer diff shiming, but I guess I used 0,4mm on one side and on the other 0,3mm. I left out the inner 5x0,5mm shim between the diff halfs (otherwise I would have had to remove more material of the diffhalf-"pin")
btw. I bought Vampire ceramic balls from radra.at - I think together with shipping it was only 9-10€
regard,
Oliver
Shqizy is offline
Old 01-31-2011, 06:20 AM
  #1869
Hi guys just ordered a tb03r and have read this whole thread i'm finding it had to get hold of several parts here in the uk and was wondering if anyone knew of a good place to look?
Jammin23 is offline
Old 01-31-2011, 06:21 AM
  #1870
The parts I'm looking for in particular are the metal outdrives and spool
Jammin23 is offline
Old 01-31-2011, 06:36 AM
  #1871
MD
MD's Avatar
Trader Rating: 136 (100%+)
I got the metal out drives on Ebay.
MD is offline
Old 01-31-2011, 06:50 AM
  #1872
I've looked there and can't find them anywhere! I even looked for 415/416 version and still nothing!
Jammin23 is offline
Old 01-31-2011, 07:01 AM
  #1873
MD
MD's Avatar
Here's the out drives and there may be cheaper sources. You can always google the part number.
http://cgi.ebay.com/54056-TAMIYA-TB-...item53e3f6c9a0
MD is offline
Old 01-31-2011, 07:14 AM
  #1874
Cool thanx for that do you know the part number for the spool?
Jammin23 is offline
Old 01-31-2011, 07:26 AM
  #1875
MD
MD's Avatar
If yo mean the direct coupling, this is it.
http://www.tamiyausa.com/product/ite...oduct-id=54125
MD is offline
