Tamiya TB-03
#1846
Well, no problem...
I also have another great news,
spec-r is presenting a gear-diff soon:
spec-r
...but I guess unfortunately "coming soon" means we'll have to wait till summer :-(
In meantime, I'm modding a M-pro gear diff (which is made for Top Photon) - this mod isn't that easy :-(
spec-r
#1847
esc coming loose
hi there.
Because of that motor cooling slot thing, there isnt enough for me to tape the esc to.
Any good ideas around this. The esc keeps coming loose.
#1848
try using shoe gloo?
Or if you need more space, use a low-profile servo.
#1850
Tranny can cope, plastic outdrives wont.
Metal Geniune tamiya diff are WAY to soft, Ive got significant wear on the metal outdrives.
Will be trying a 13.5T soon, motor just arrived.
#1851
Taking it to the drivetrain limit!
Just my 2$
#1852
I've raced my TB in 10.5 (as well as 13.5) and it handled it well.
The sound you get from the gearbox is wicked!
Yes definitely go with the metal out drives and the most important part make sure you shim the ring and pinion correctly. I would also recommend just a tiny bit of lube on the gear teeth as well. (17.5 I run them dry)
#1854
Well, no problem...
spec-r
spec-r
"This is longlife and no need to repair often which provides and enlarges the car much powerful."
I would like my car enlarged much powerful
-sorry, coudln't resist
#1855
Tb02 parts is hard to find or some of them is discontinued. wondering if any of tb03 parts like the front spool will fit my Tb02.
Any recommendation?
Any recommendation?
#1856
3racing 7075 Alu diff ??
Hi there
Has anyone tried the 3racing 7075 Alu diff shaft/outdrives ??
Ive found the Tamiya Alu diff's outdrives to be far too soft & are wondering if the 3racing ones are any harder ??
Merry Xmas(late)
Merry Xmas(late)
#1857
Speaking of outdrives, does anyone know a part number of a c-clip (blades) that fits into the option TB-03 aluminum outdrives? I tried T.O.P blades because I didnt have the tamiya ones in stock, but they are too fat.
#1858
I have some 3racing ones & some xray ones I can measure up if you know the thickness of the Tamiya c-clips (in mm)
#1859
Thanks guys, I found the swingshaft protectors at MSI. Appreciated!
