Tekin RS ESC sensored >
Old 03-09-2010, 11:34 PM
  #13156
Originally Posted by Skiddins
The standard 'central' one, temps never got very high either, I could always keep my hand on the motor.
Skiddins
Ok, so 40 degrees then (std on the X12)
cheers
chris_dono is offline
Old 03-10-2010, 01:01 AM
  #13157
smilekt's Avatar
Tekin Rs Pro running with fan heatsink or not ... ?
smilekt is offline
Old 03-10-2010, 01:41 AM
  #13158
Skitee's Avatar
The Tekin RS has longer solder posts for the wires which double as heat sinks for the fet pcb's.
You only need to have a fan blowing across the posts if you are going to run low turn modified motors, I have run an LRP X-12 7.5 on RS pro without a fan and didn't have any thermal issues. You don't need a fan for any stock class(10.5/13.5/17.5/21.5) racing.
Skitee is offline
Old 03-10-2010, 02:18 AM
  #13159
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone have any good 10.5 settings? The track is a small asphalt track, with 14-15 second lap times Not sure on measurement as im travelling to an event there. I will most likely use a Duo 2, or a Novak Ballistic.
Thanks,
Antoni
Yokomo_Ant3 is offline
Old 03-10-2010, 02:49 AM
  #13160
Skitee's Avatar
Antoni,
Here's my 10.5 setup, hope it helps.
Track size 43M x 23M / 141Ft x 75Ft, longest straight 36M / 118Ft
10.5 Speed Passion V3
Motor Timing : +5
Boost : 50
Turbo : 10
Turbo delay : .5
Turbo ramp : 1
Throttle Profile : 3
Start RPM : 4000ish
End RPM : 18000ish
FDR : 8.33
Motor Temp : 68c/154f
Regards
Shaun
Skitee is offline
Old 03-10-2010, 04:13 AM
  #13161
Skiddins's Avatar
Are the timing settings in V203 relevant to actual timing in degree's or just a measuable scale related to the timing in degree's?
Skiddins is offline
Old 03-10-2010, 05:12 AM
  #13162
Originally Posted by Skitee
Antoni,
Motor Timing : +5
Boost : 50
Turbo : 10
Turbo delay : .5
Turbo ramp : 1
Start RPM : 4000ish
End RPM : 18000ish
FDR : 8.33
Regards
Shaun
Old 03-10-2010, 06:28 AM
  #13163
TrevCoult's Avatar
All the sensored settings are in degrees. Timing advance in dual mode is a percentage.
Trev
TrevCoult is offline
Old 03-10-2010, 06:45 AM
  #13164
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by razzor
There was talk from Tekin not long after v203 was released about a revised software version with a better display, layout.
Any news on that Randy or Prez ???
+100
A simpler easier to see display would be great.
Question: When should you use dual mode versus sensored and vice versa?
Question: Anyone got a good starting point for a 1/10 2wd SCT 13.5 setup?
Cain is offline
Old 03-10-2010, 07:03 AM
  #13165
theisgroup's Avatar
Originally Posted by buffalobill989
http://www.rctech.net/forum/electric...ed-my-car.html
looks like he had the same issue i think. dont know if it helps or not
i am pretty sure this is completely different, as chris's car was under heavy load when this happened. the other insident seams to have happened under zero load from the driver's description
theisgroup is offline
Old 03-10-2010, 08:08 AM
  #13166
Team Tekin
Randy_Pike's Avatar
The new "layout" is coming...
Randy_Pike is offline
Old 03-10-2010, 08:12 AM
  #13167
niznai's Avatar
You are starting to get faster than us.
Please, we are now faster than most other people. Please, a Linux/Mac version? Please? Please? I would be happy with a very simple layout with absolutely no frills (my eeePC displays such an image, but pops out a message something or other about the window, I just ignore it)
niznai is offline
Old 03-10-2010, 08:17 AM
  #13168
Tech Legend
Cain's Avatar
great. something simple and easy on the eyes would be a big plus.
Cain is offline
Old 03-10-2010, 08:20 AM
  #13169
Does the new layout make my pc also run faster like my car
mikky32 is offline
Old 03-10-2010, 10:18 AM
  #13170
TheCoolCanFanMan's Avatar
HaHaHaHaHaHaHaHa very gd
Malc
TheCoolCanFanMan is offline
