Tekin RS ESC sensored
#8986
With the speedo switch off there is no voltage cutoff protection at all. SO I always reccomend running switch on.
#8987
Tekin RS and 13.5 redline settings
Hi Randy
What settings for my esc and motor+ FDR would you recommend for this application. Running in 13.5 superstock class 310 metre long track using rubber tyres, and with the fastest time in this class being a 21 sec lap.
As you can see its a large medium grip track and the straight is approx 60metres long.
Thanks in advance Cheers Dave
#8988
#8989
silly question;
what's the benefit of cutting the switch off?
cheers
cheers
#8991
I have tested a heavier gearing with the folowing setup.
Boost 0
Turbo Max
Turbo delay 0,4
Gearing 6,16FDR
Laptimes went down with 0,4sec.
Motor temp was not that good. 111 degrees C.
I gear back tomorrow but the speedo was great today.
After the Belgium champion the second fastest on the track.
THe number 2 of the first 2 races behind me on 0,13sec.
He came to watch witch motor I used.
Tomorrow we go again. Must do some small changes to my car.
Also gear lighter. I don't go back to 7,6FDR but I think 7,0FDR.
Last news about the SXX speedo. It is slower than the EA. The SXX stock spec is only updated with other software than the SXX TC.
Boost 0
Turbo Max
Turbo delay 0,4
Gearing 6,16FDR
#8993
Motor was a LRP 10,5T X11. It's timing is about 12.
#8994
wat is ea
#8996
If I am running 1s in 1/12 scale and never plan to run more than about 8-9 minutes, why would I need the voltage cutoff? I'm only using about 2,100-2,300mah per run with a 13.5. And if I were so solder the two wires together, wouldn't that be the same as turning the switch on?
#8997
switches
if you are running a receiver pack you have the OPTION of running speed control switch ON or OFF///
if you are running a booster BOTH speed control and booster swithes have to be ON...
#8998
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
from the way i have read the post's yes that would be the correct answer. i run booster and have to have both switches on for car to operate the correct way. randy will show up and correct me if i am wrong. jeremy
#9000
Will hotwire work on a netbook running Windows 7 ?
