Tekin RS ESC sensored
#7847
win7 on 32bit. the problem is that M$ require that you have a 64bit OS and 64bit compilers to build 64bit apps now. so it now requires people to have of everything. that is one of the reasons I did not opt for 64bit. it can manage memory like a champ, but when there are only 2 apps that run, memory is not the issue. hell at one point M$'s own office would not run on their 64bit OS
#7848
Now I have a hotwire I can't use and ESC's that I bought for the adjustability but can't adjust as well because Tekin won't write the software?
Anyone want to buy a few RS Pro's? Maybe I'll go to Orca's.
#7850
put me second in line. I have yet to see an rs or rs pro sit in the for sale forum for more then 1 week
#7853
The last reply on their own forums is from April saying soon. What month is this?
#7857
Don't tell me that more than a few of us have been waiting and waiting for this to come out? Tekin hasn't said a release date. I can't fault them for that. But saying coming soon and still no word 6 months later? Can you not see the frustration?
#7859
The largest cause for this is having your radio wander, even if by a tiny amount, as it "warms up" in your hand. The rs has near zero tolerance when it comes to "full" throttle. Most get around this by performing setup at epa's of 90 and then bumping up to 100 to make sure the esc see's full throttle.
If your delay is set to low and you're not winding out before it hits it seems to go away/ not kick in properly.
Also, if you radio creeps it makes it go away. I get this at my track when a 4pk is in my heat. Set your throttle to like 90/95 and then sync it to the esc. Then turn it back up. Seems to work for me.
