Tekin RS ESC sensored
We run boosted 17.5 TC onroad on a small-medium outdoor track (30m/100' straight). I currently have a Fantom Ion3 in the car and started with Hara's setup:
Boost: 50
Turbo: 14
Start: 5,400rpm
End: 20,000rpm
Delay: .14
Ramp: 2.0
I started with an FDR of around 6.2.
Overall, it feels like not enough bottom end, but seems to be accelerating hard still towards the end of the straight. Looks like a setup for a bigger track. Temps after 5mins are in the 60degC range.
I'm hoping someone has some suggestions for boosting the bottom end. I don't really think I want to gear much shorter than that, so thinking of lowering the rpm range (start & end) but dropping the boost a little to keep temps in check. Has anyone found a good combination for this?
Boost: 50
Turbo: 14
Start: 5,400rpm
End: 20,000rpm
Delay: .14
Ramp: 2.0
Hi PDR, try this
Boost 46
Turbo 15
Start 2950
End 13996
Delay 1.2
Ramp 2
Min throttle 20
And you might want to try dropping a tooth or two and give the motor plus one mark of timing.
Does anyone have a setup for 1 cell 17.5 oval open? Running on a 180ft runline flat carpet.
Cheers,
Phil.
Randy
Is there any update on the Hotwire programming for Mac OS? I'm still keeping my hopes up. Hotwire is the only thing I have left on my Windows based laptop.
Trader Rating: 89 (100%+)
13.5 blinky WGT
what is a good statring point for gearing this with the tekin 223? 13.5 wgt blinky?
R/C Tech Elite Member
83mm start for 13.5 blinky wgt. Thunder power 13.5.
Has anyone had a problem with the new Trinity D3.5?
I'm having a sensor issues it seems. Every once in a while during a 5min run, coming out of a corner my Touring Car will stutter like when the ESC does not detect the sensor signal and can't start. This happens randomly.
I have this issues with 2 brand new 17.5's. My Thunder Power and Novak work fine.
Turns out the sensor board on my Revtech was bad. Replaced it and it was perfectly fine.
Hey, what LEDs flash when you lvc, also will the tekin rs just stop when it hits lvc? Thanks
Tekin RS (not Pro) faulty?
It'll take settings for 212 & 223, either 'Blinky' or timed/boosted via the hotwire but the esc won't let the motor get rev out. Runs about 2/3rd's the pace of when running 13.5 blinky.
Changed power cap, sensor lead, batteries to no avail
It won't work in 2s but with a booster wired in it'll do 1s
Any ideas?
Any ideas?
Blinky and throttle profile
I have just switch to 17.5 blinky and was wondering what throttle profile curve people use. Do most select THP5 and forget it?
Do you notice any difference in blinky?
