Tekin RS ESC sensored
#7636
I just upgraded the firmware on my RS to V200 and now all LEDs are dimly lit. I tried resettings the ESC by pushing the inc and mode buttons but it didn't help. I can't downgrade the firmware because my hotwire won't even recognize that the ESC is plugged in. Any other tips to revive it or do I need to send it back to Tekin?
#7637
if they blinks,you need to press mode three seconds and calibrate your radio
Neutral- forward-brake
#7639
Chris, sounds like it needs to go back. It's worth a call to HQ to see if service has any other ideas before sending it back. If you need one to borrow, let me know. I have a spare pro.
#7640
sorry guys
I should stop loading software to try cos anytime this could happen ...
#7642
Suspended
It's probably been asked before but i'm far too partially drunk to look for it now.....
How does the R1 Pro compare to the Rs Pro on the track (touring car).
Cheers Nick
Cheers Nick
#7647
WOW, I leave you guys alone for just a few hours and look what happesn!? LOL
I do think that there are tracks and situations where the lower delay will help if it's done right. For instance taking even MORE timing boost out and making sure you're actually getting to full turbo which takes a full second. A setup like this will feel different and may be the fast setup.
Offroad is where this is also going to be useful, yes I play in the dirt!
We had a lot of requests for the lower delay. I've said it a hundred times: You talk, we listen....
If you have all dim lights and the Hotwire will not recognize the unit the software update might have been interupted. Try hooking it up to a battery, doing a factory reset. If it doesn't recover contact [email protected] for an RA# it will need to come home.
#7648
Suspended
I shall be running 10.5 mainly, maybe 6.5 but very rarely..
Cheers Nick
Cheers Nick
#7649
