Tekin RS ESC sensored
#5057
I got the V199 from Randy.
I mean with motor 12, the motor timing that I use.
The Turbo max is the maximum setting you can use with the Turbo.
Just like Max Boost.
The Maximum Turbo is 20.
Just download the newest version and uninstall the old version.
I can say that the Turbo is great.
I try an other setting next race. This will be over 2 weeks.
Than I try with a bit lower boost.
I have enough infield power and I hope to get some more power corner out and ad the beginning of the straight.
I have so much power that it keeps accelerating . The straight is to short to reach the top speed.
So I hope with a lower Boost that I will come closer to my top speed and that I will accelerate the first part of the straight more.
I over take the SPX drivers on the straight. It's just great to see there faces when I do a warm up lap before the finals.
Than they ask me were I get that power from and if i'm not geared to heavy.
When I say that I'm geared on 6.3FDR, than they look strange.
The lightest geared SPX driver drives with a 5,7FDR.
All the others are 5,2FDR and the TC drivers are on 4,7FDR.
Tekin is fast so not the fastest speedo there is.
Now more and more drivers are changing there GM and SPX for a Tekin.
I let an other club member drive with my car. He was impressed with the speedo.
He sold his GM and he wanted a SPX but now he is thinking of the Tekin because of the way it drives.
Tekin is growing out here after a slow start.
More and more drivers discover the power of the Tekin speedo and motor out here.
First it was the motor, now the Tekin RS / RS Pro.
Also the service of Tekin is great.
I am assuming by the ratios you have quoted this is with a 10.5 motor ? Is this also on that massive track you posted pics of a quite a few pages back ?
#5059
The latest download is 198 and that is the one I have.
V199 is not public, so not sure how you got it.
Some people have taken a shot at explaining what the Turbo function feels like but not what it actually does (i.e. what do the electronics do). Is it anything like the turbo function on old speedos where it was actually a burst of maximum current (temporarily overriding the current limiting settings)? Think in terms of the GM V12xc or the LRP Quantum 3 which both had this function.
#5060
Thank you, that clears things a bit. Still don't understand what Turbo you're talking about though. There is no turbo function on my hotwire/RS pro.
#5061
http://www.macdebaanbrekers.nl/
I use a Tekin Redline motor.
I got it from Randy Pike.
He wanted to now how it went and how I liked it.
In the beginning it was hard t find a good setup because I was still thinking of the old settings.
But now I found out with help from Randy that you can use a lower boost and a lighter gearing, Also on the big tracks.
No it will not put an extra current true your motor.
So you don't need to worry about that. My motor stays cooler than without the Turbo.
The Tekin RS Pro is the only speedo that keeps the motor temp under the 165F and goes above the 80km/h. The GM did it also but 1 motor blow up in 5 laps and the other motor was way above the 180F.
As I let my motor come above the 180F, than I will go even faster.
But I don't have to take risks to go fast.
#5062
If what you said is true, then the turbo function of the RS is similar indeed to that of the brushed speedos of the past (as I have mentioned above)
One question remains then. Is the turbo going to override the current limiter settings?
#5063
Turbo won't have any effect on the current limiter settings, turbo only comes in when you've been at full throttle for a preset amount of time, the current limiter comes in at the first pull of the throttle.
#5064
#5065
Thank you Krio, that's the kind of thing I was after.
If what you said is indeed true, then the turbo function of the RS is similar indeed to that of the brushed speedos of the past (as I have mentioned above)
Also will the speedo not get hotter.
I don't have any problems with the temp at all.
It's even harder to get a to hot motor.
#5066
So last night we were running some vintage 21.5 cars and WOW the tekin pulled ALL of the cars down the back(mabe 70foot)... thing is blistering fast for 21.5... i could run up on a tc spec and ran his rear end with little effort if he didnt get out of the way... the KO BMC was the only speedo to out run me on back straight.... thus far im happy with the RS PRO.... I have not turned my end bell like the guy with the KO has either.... I could out run them all in the field....
Alex
Alex
#5067
Alex
Alex
and witch motor were you using?
Do you have photo's of the Track?
#5068
Alex
Alex
A little detail about the track might help too (i.e. carpet/asphalt and twisty/open).
Cheers
PS Hehe, someone beat me. Your bits have a shorter distance to travel, mikky!
#5069
hehehe yes I think so.
I used the Turbo on it
#5070
HA guys tomorrow im going to a short track to run at another club that i dont normally run at with about 20m straight should i drop my boost
Monday i ran it for the first time and had the boost on 20 and have been advised to drop it to 18
do i drop it again for shorter tracks
thanks in advance
thanks in advance
