Tekin RS ESC sensored >
Old 03-26-2009, 02:45 PM
  #3016
Trips's Avatar
Trader Rating: 16 (100%+)
Randy,
I think my emails to you are getting filtered or blocked for some reasdon... I emailed you two nights ago right after you announced 1.94's availability, and again yesterday. I'm sending you a PM with my details.
Trips is offline
Old 03-26-2009, 03:05 PM
  #3017
2056dennis's Avatar
Trader Rating: 134 (100%+)
Default Randy
Randy you have mail / Trips you have mail
2056dennis is offline
Old 03-26-2009, 03:27 PM
  #3018
sportpak's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Trips
Randy,
Me too....
sportpak is offline
Old 03-26-2009, 03:29 PM
  #3019
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Got to love technology! I got my RS on Tuesday and have already upgraded the software twice (180 to 189 to 194) in it before getting to the track to run it.
A+ though for Randy and Tekin's tech support for all us racer's!
Cameron Kellogg is offline
Old 03-26-2009, 03:31 PM
  #3020
okayplayer
Guest
Posts: n/a
Hi,
I'm really happy with the performances of my Tekin RSPRO and Tekin 6.5T on a 23T pinion (that's quite comparable in terms of speed with a 5.5T on a 21T pinion).
I noticed today that the motor shaft is moving (up and down); let's say that when I go for a little throttle, the shaft is moving to the exterior ... 4mm (and looking at the top it's huge!)
I'm wondering if it's a manufacturing issue ... and how can I fix that ? Someone ever had this issue?
(I live in south france, so sending back the motor to Tekin USA, will cost me more than to buy a new motor)
Thanks a lot,
Cédric
PS: anyone could send me the 194 ?
Old 03-26-2009, 03:51 PM
  #3021
Grenade10's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Randy_Pike
Grenade,
There is a large improvement in low voltage operation. The actual 1s profile isn't in there yet but 194 is superior for 4 cell and 1s lipo.
Thanks!!
I'll make a run or two with 189 and then upgrade to 194 Sunday.
Grenade10 is offline
Old 03-26-2009, 04:48 PM
  #3022
Trader Rating: 31 (100%+)
Originally Posted by okayplayer
Hi,
Thanks a lot,
Cédric
Check the end of the motor around where the Tekin Sticker is. It probably is separating from the can and causing the slop. The same thing just happened to me and some others on here. Contact Randy and he will tell you for sure. Theres a simple fix. Mine is good as new.
jjdoyle is offline
Old 03-26-2009, 07:47 PM
  #3023
afr0sch's Avatar
Trader Rating: 95 (100%+)
Default thx Randy
thanks for the 194 software Randy! U da MAN!
afr0sch is offline
Old 03-27-2009, 04:03 AM
  #3024
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Default New RS Software
PM Sent for the new software. Ordered the RS today. Should be here tuesday. So cant wait to test it out next weekend at challenge cup.
A Ilievski is offline
Old 03-27-2009, 05:51 AM
  #3025
okayplayer
Guest
Posts: n/a
Only the shaft is moving - The area that show the little issue is at the intersection of the shaft and the can, where the shaft goes inside the can.
You'll find here two pictures, high res, showing :
Default shaft situation : http://www.gamani.org/tekin/DSC_9346.JPG
Moving shaft situation : http://www.gamani.org/tekin/DSC_9347.JPG
Here're some lower resolution for small bandwidth:
Cédric
Old 03-27-2009, 06:44 AM
  #3026
Yeah im not sure your better off contacting Randy. I wish I would have taken an image of mine before I fixed it, but here is an image of a new motor with no gap. Basically the gap allows the rotor to float back and forth in the can because the gap creates extra space. Once again this motor in the picture is fine but mine had about an 1/8 inch gap where the arrow is pointing in this image.
jjdoyle is offline
Old 03-27-2009, 07:52 AM
  #3027
Team Tekin
Randy_Pike's Avatar
Okayplayer: I'm not seeing a whole lot of difference between the two photos. Maybe I haven't had enough coffee this morning!
Shoot me an email and we can go over it: [email protected]
Fellow racers, for those of you that sent me a pm regarding software check your mail now. I sent out the file with a .txt extension to help in "slipping it passed" email wardens and filtering.
I've gotten the requests back down to none as of this very second.
I'm working as fast as I can to get it out.
Let me know who's missing it!
Randy_Pike is offline
Old 03-27-2009, 08:42 AM
  #3028
clean your motor
Good job Randy, you are working hard.
You say it gives more power on 4 cell. does it now also give some more power to 5 cell?
It field like it did.
testing it tomorow as it is dry or els sunday or monday or wensday
mikky32 is offline
Old 03-27-2009, 09:07 AM
  #3029
PitNamedGordie's Avatar
Randy,
You mentioned that the 194 software is supposed to be more efficient, correct? I assume efficiency can be measured in what temps I see when I come off the track. I was at my track yesterday and with the same gearing and timing that I had with the 189 software I noticed much lower temps when running 194. In the past with the 189 I would reach 170 degrees after a 6 - 7 minute practice run. With the 194 I ran for 10 minutes plus and came off the track at 170-175. With that said the track layout changed since last week so I'm not sure how much that factors in. I guess a good test would be to run 189 for 6 minutes and then 194 for 6 minutes and check the temps. I was just curious if my temp change was due to the software change?
I am running an Xray 008/009 with a Speed Passion 17.5 in sensored mode and 18 boost.
PitNamedGordie is offline
Old 03-27-2009, 09:23 AM
  #3030
okayplayer
Guest
Posts: n/a
mail sent
