Tekin RS ESC sensored >
Old 01-30-2009, 07:15 AM
  #2266
PitNamedGordie's Avatar
Originally Posted by billb60
I'm only borrowing the hotwire for my pc and esc.
The settings stay in the ESC. So you can borrow someones Hotwire to program your ESC.
PitNamedGordie is offline
Old 01-30-2009, 08:42 AM
  #2267
Team Tekin
TY@TEAMTEKIN's Avatar
Exactly, once the other dude plugs his ESC in, his settings will show up on the HotWire as it reads the settings off the ESC.
TY@TEAMTEKIN is offline
Old 01-30-2009, 09:43 AM
  #2268
Trader Rating: 16 (100%+)
Originally Posted by miller tyme
As I understand it, "Push Control" is basicaly applying 'creep' in a brushed motor only during slowdown , to allow it to roll to a stop like a brushless rather than just have the magnets suck the armature to a stop
Miller Tyme, thanks for the reply. I understand the function. Will "push control" push a brushless motor in the same way it does a brushed motor? I am looking at ways to maintain a higher corner speed in case I let out of the throttle too much.
Adim_X is offline
Old 01-30-2009, 09:50 AM
  #2269
Team Tekin
Randy_Pike's Avatar
Adim, No it will not. That is a brushed only feature. If you're looking to keep corner speed up make sure to have 0 drag brake.
Randy_Pike is offline
Old 01-30-2009, 10:27 AM
  #2270
wingracer's Avatar
Trader Rating: 24 (100%+)
I would think you could just bump up the throttle trim on the radio a bit to put a little neutral roll in the car. You would have to hold the brakes on the start line of course but racers have been doing this for years. I'm not a fan of it myself but I don't see why it wouldn't work with brushless too.
wingracer is offline
Old 01-30-2009, 10:38 AM
  #2271
It works but with brushless i don't do it because the brushless motor rolls enough.
mikky32 is offline
Old 01-30-2009, 10:55 AM
  #2272
I think a "save settings" would be an EXCELLENT feature of hotwire. Our track purchased a hotwire for all the guys running (or starting to run) the tekin esc's. It was done so the racer didn't feel like he HAD to have the hotwire, or didn't want to bring their laptop to the weekly club races. I think it's worked out well.
I think the ability to "try" somebody elses settings without having to hook it up, or having to remember what settings a person had.. you could just "open" a "settings" file then upload it to the esc. Seems simple enough, but I'm not a programmer.
later.
acyrier is offline
Old 01-30-2009, 11:38 AM
  #2273
later.
I think Tekin is working on that in there next release of software
Old 01-30-2009, 12:00 PM
  #2274
Team Tekin
Tekin Prez's Avatar
Actually we turned on PUSH in BL mode in the newest software version coming. Many of the spec motors do have a lot of cog torque and enough drag to make some want it. It was a brushed inspired feature (Pike push actually) but also has merit in BL.
We do not like people to trim the throttle out of nuetral or we do not initialize because we do not see the nuetral we expect at turn on. Trimming the throttle or putting Nuetral Width too tight can also kill Drag Brake. Some radios are not consistent enough to always return to the same nuetral if it is set too tight. If we do not see nuetral there is no PUSH or Drag Brake activated.
Yes we are also adding the ability to save setups in the hotwire, name them and pass them around as individual files.
Tekin Prez
Tekin Prez is offline
Old 01-31-2009, 12:01 AM
  #2275
Originally Posted by Trips
I'm not sure what exactly the RS looks for, but the sensor LED's (last three on the RS) seem to stop flashing once the motor gets up to a certain RPM. There's probably more to it than just switching to sensorless based on RPM tho, but it might be proprietary info.
thought it would be... but thanks for taking your time
g
gortan is offline
Old 01-31-2009, 01:50 AM
  #2276
hi...
i was wondering what would the best way to mount the esc to a 1/10th tc.
what the stuff that's used to fix the esc to the package when new in the box... look like some hot glue.
anything similar that can be used on a car without investing in hot glue gun? that would be great as it is extremely sticky and able to come off clean if necessary...
thanks
g
gortan is offline
Old 01-31-2009, 02:03 AM
  #2277
Trips's Avatar
Parma makes a GREAT servo tape that is made of silicone rubber. It sticks real well, but when you peel it it always comes off in one clean piece... noo crumbs, no residue.
Trips is offline
Old 01-31-2009, 02:29 AM
  #2278
thanks trips... always helpful.
I'm looking at it right now but cannot make out how thick it is. Is it foam type?
My only concern is, if it is too thin, then it might not take up any imperfections between the two flat surfaces, reducing adhesion strength...
g
gortan is offline
Old 01-31-2009, 02:50 AM
  #2279
1armed1's Avatar
Trader Rating: 79 (100%+)
Go to your local Walmart, Lowes or Autozone.
Look for 3m body molding/ mounting tape.
I get the 1" wide roll, it's $6-7 depending on where you get it but the roll will last forever.
It sticks very well and when it comes time to remove it, it peels off very clean.
later
Dayton
1armed1 is offline
Old 01-31-2009, 02:55 AM
  #2280
1armed1's Avatar
Here is what it looks like.
http://www.autozone.com/selectedZip,.../selectZip.htm
You can find it cheaper at Walmart and lowes.
later
Dayton
1armed1 is offline
