Tekin RS ESC sensored >
Old 12-04-2010, 03:30 PM
  #18676
hairy's Avatar
Yes and they are working.as a matter fo fact the leds all light up when the throttle is pulled and the motor won't turn over.
hairy is offline
Old 12-04-2010, 03:33 PM
  #18677
Regional Moderator
CarbonJoe's Avatar
Here are my 17.5 X-12 settings 40x90 foot carpet track
Motor comes off around 195 degrees, which is where the X-12 seems to like to run.
Car is stupid fast, almost like a 10.5 down the straight.
17.5 Foam
V2.03
LRP X-12 -4 dot insert
Gearing 35/110 5.34 FDR
Drag Brake off
Reverse Strength off
Brake Strength 85
Neutral Width 10
Motor Type BL-FW
Throttle Profile 5
Voltage Cutoff off
Push Control off
Timing Boost 45
Turbo 10
Sensored checked
Turbo Delay 0.0
Turbo Ramp 3.0
Start RPM 2721
End RPM 10001
Tire size 2.26in/57.5mm
Rollout 1.33in/33.81mm
CarbonJoe is offline
Old 12-04-2010, 03:34 PM
  #18678
Team Tekin
Randy_Pike's Avatar
Ok, this sounds like the unit hasn't armed yet. Please set your NW setting to 56 or higher. Then see if the unit powers up properly.
What transmitter/receiver are you using?
Randy_Pike is offline
Old 12-04-2010, 03:37 PM
  #18679
My settings are as follows
FDR 7.53
Carpet track with good traction and a straight of approx 80ft.
V212
boost 51
turbo 10
Timing 80
Start rpm 4278
End rpm 10000
turbo delay.1
Turbo ramp 2
Cut off 2s
sensored mode
motor direction normal
throttle profile 4
current limit 98
drag brake off
brake strength 100
Reverse speed off
nuetral width 8
push control 20
throttle min and brake min at default setting
It probably won't help (as it does sound like some sensor problem in the motor), but an FDR of 7.53 with a 17.5T does sound extreme. I race at a fairly small track (compared to those big ETS, Snowbirds and such tracks), and I use a FDR of 5.7. AFAIK 5.5-6.5 is the norm with a 17.5T
Nilks is offline
Old 12-04-2010, 03:38 PM
  #18680
hairy's Avatar
What is the NW setting?
This happens after I have run the car two or three times and go back to the pit to let it cool off change battery and then it happens.The battery is the same on it ran it's first run with without any rpoblems.
Futaba 3PK super and an r603ff receiver.
hairy is offline
  #18681
hairy's Avatar
sorry i'm slow Neutral width DUH!
hairy is offline
Old 12-04-2010, 03:45 PM
  #18682
hairy's Avatar
I'm running basically the same fdr as the other running a R\S and they arn't having the problem I am. Randy I tried reseting everything and the problem still exists. I also have tried other motors and the problem still exists, so I can't see it being the sensor board in the motor.
hairy is offline
Old 12-04-2010, 03:48 PM
  #18683
I run with a 13,5 that fdr.
he uses to much boost. 40 to 45 is more than enough.
gearing a bit heavier is better.
as you turn the motor by hand' light there any leds on your speedo?
toptek is offline
Old 12-04-2010, 03:49 PM
  #18684
hairy's Avatar
yes they light up, I have tried several other motors and the they are all the same.
hairy is offline
Old 12-04-2010, 03:50 PM
  #18685
hairy's Avatar
Are my settings able to burn out the speed controller?
hairy is offline
Old 12-04-2010, 03:56 PM
  #18686
It shouldn't. I use more extreme settings (aside from the FDR) and mine holds up fine.
Nilks is offline
Old 12-04-2010, 04:00 PM
  #18687
burn out your motor yes speedo i don't tink so.
clean the connections from your sensor wire on your speedo and motor.
check them well. durt can cause problems.
toptek is offline
Old 12-04-2010, 04:23 PM
  #18688
hairy's Avatar
O.k let me say this.... as far as the motor being the problem, I just put a brand new out of the box speedo in the car this week from where Tekin replaced the last one(because it was doing the same thing). Same motor as before new speedo to the track this a.m.
After three runs of six minutes and a break between each as if in a race situation,every thing is fine. go out for a fourth run and the problem comes back, Something happened to the speed controler. If it's not my settings and it sure isn't the motor(because it is doing it with two other motors, that run fine in someone elses car after I tested it), then what is going on?
hairy is offline
Old 12-04-2010, 04:28 PM
  #18689
hairy's Avatar
I guess I'll just send it in( again) and wait for a replacement don't have much choice I am not having fun this way.
hairy is offline
Old 12-04-2010, 04:55 PM
  #18690
use an other motor as you get a new speedo.
ask if tekin will test the speedo for you.
toptek is offline
