Tekin RS ESC sensored
I haven't messed with it much, but I am running 20-25 initial throttle. Initial brake, I don't really care as I never had a problem with the brake feel. I have a good setup you can use Jason. I am running the Duo3 now though.
That's the one I used when I had a 17.5 on my 12th. As the notes say on it it's really quick for the first 3 mins then drops off. Still a great setup though. Just make sure your roll out is right. Think I was at 80mmpr. Seems high but worked for me in 17.5 1s
what is the max amperage that an rs will pull from a battery?
ok how do you find out what the motor will draw?
rs help
i was racing tonight and the truck was running great, then it just shut down. i get the flashing led's 1-2 and 6-7 which tells me that the wrong motor type is selected. i replaced the sensor wire, same problem, put in a new motor, same problem, i then checked the settings thru hotwire and everything looks good. tried a factory reset, same problem. is my speedo shot? it's only 2 months old.
The RS is rated for brushless 5 turn and up, 36mm can in 2wd. Here is the specs on it.
http://www.teamtekin.com/rs.html
Tekin rs
I am having the same problem I was racing everything was great and then it stopped and 1,2,6,7 was flashing is this happening alot and whats the problem
Please check your solder connections on the motor and ESC.I had one come loose on the ESC and it flashed the same lights.It didn't look loose but it was....soldered it back up and it was good to go
Tekin rs
I tried that another motor resetting the ese and sensor wire still did the same thing
Hi Con. Were you the guy I met racing Stock TC last weekend at Lou's? If so, good racing sir. Not sure if I said that there. My ride back to the city left right after the mains.
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Just ran 212 tonight in my 12r5.1. Is it me or do the brakes seem weaker when using timing boost? I remember 208 having MUCH stronger brakes.
Nevermind.
