Tekin RS ESC sensored
Tekin on sale....
I spread the word on this locally, but in case anyone in the neighborhood watches this thread and not our local forum:
Tekin RS/RS Pro Programming Clinic
with Pete Waydo, Tekin Team Driver
Tonight, 10/12/10 6:30 pm
Brooker Tracker RC, Newbury Park, CA (www.brookertrackerrc.com)
Space is limited! Please RSVP by PM.
GM 13.5 with a Tekin rs Pro
Has any one got a setup for the 1600 gause version of this motor. I will be racing on carpet with an Xray 009 with rubber tyres. Thanks
When you speak of N on the orange, are you talking about the factory setting of the motor? If not then what is N on the orange 17.5?
Thanks and God Bless
no live feed via internet? would be nice for us outside the US.
can anybody put me in the ball park for a mod setup for tekin rs with a 6.5 or a 7.5 touring rubber on a 100ft by 48ft indoor asphalt track? and maybe 13.5 to?
But just to double check, would I turn down the turbo to say 5, gear down like 4 teeth and check temps every 2 minutes and if temps are still low, gear up to the right gearing continuing to check on temps THEN slowly turn up turbo up to Hara's settings? Incidentally, what is a safe/max motor temp for the "orange" motor?
Thanks,
Ivan
Ivan yes use the gear up slowly and add turbo slowly idea, it works best.
For "that" motor I believe they say nothing more than 180.
i am sure this has been covered, but an hour of searching didn't pay off.
i am trying to get set up for a zero-timing 13.5 WGT class, and am behind the power curve on motor selection and endbell timing.
i have 3 motors to choose from:
1. tekin (currently in use in 1/12 car, open boosted class)
2. speed passion v2? this is the black can fixed timing version
3. lrp x-12
1, the speed passion seemed down on speed compared to another car on the track.
2, the lrp was better but not there, using the 3dot insert, apparently i should have stayed with the 2dot.
with limited practice time on raceday, so i was looking for suggestions. with the 3 motors above, i would like to have 2 competitive cars, 1/12 boosted, and wgt zero-timed.
my next step is try the 2dot in spec mode. if this doesn't payoff, then swap motors, then find a suggested endbell timing for the tekin in spec mode and lrp in boost mode.
oops, forgot the state the question(s):
what endbell timing would you suggest for 13.5 1/12 boosted and for 13.5 wgt spec 0 timing for tekin redline and lrpX-12 13.5 motors?
the only recent info that i found was 20degrees on a duo for the spec timing case.
thanks very much any help on this subject.
3. lrp x-12
Hi guys.
I am looking for a little bit more speed. My settings are:
Motor: Speed Passion V3 17.5T
FDR: 5.95
Motor Timing: +3 degrees
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
I was perfectly fine with the speed with this settings, but another driver at the track (a modified top-driver, now driving SuperStock 17.5T) has the same speed as a 5.0T modified down the straight (not joking!).
How can I optimize my settings? The temp on the motor after 5 minutes, is 43 degrees celcius, and the ESC is 34 celcius.
Video of the track:
http://rcgalleri.dk/html/vid_vis.asp?VideoID=13076
FDR: 5.95
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
Video of the track:
Bump boost to 50 and put your gearing at a 7.0 fdr
Yes, the markings are + ||| N ||| -
Regards,
Carter
Regards,
Carter
"45 30 15"
Now it came with the motor engraved mark very near the 30 degree timing. So would this original position be the neutral?
Hi guys.
FDR: 5.95
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
Video of the track:
FDR: 5.95
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
Video of the track:
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Hi guys.
FDR: 5.95
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
Video of the track:
FDR: 5.95
Drag Brake: 25
Brake Strength: 100
Neutral Width: 10
Throttle Profile: 3
Push Control: Off
Boost: 45
Turbo: 15
Turbo Delay: 0.2
Sensored: On
End RPM: 15000
Start RPM: 5000
Turbo Ramp: 2.0
Video of the track:
Did I mention awesome track?
-rocky b
