Tekin RS ESC sensored
It does have acceleration but not enuff to outrun the lower turn motor of other car using hobbywing mod turbo software
Cheers, ill turn it down and work in 10-15 range =)
Ok guys... getting ready for Vegas and I have to run the 2.08 with the no timing profile.
Not sure how to get this profile... its supposed to flash some sort of code for the tech guys to know there is no advance programed in.
So do I just turn all the advances to zero or is there a special setting I didnt see?
Well I had throttle profile 5 and all the timing turned to zero and it flashes at nuetral... great looks like a call to Tekin tomorrow
If you've got 208 loaded into the unit simply use the RS's onboard buttons and use the "mode" button to select "TP" or Timing Profile(208+) and then use the "INC" button to select led 1.
DONE
DONE
As for the blink on timing profile 0, it's a fast blink on the middle led. Every few seconds, all profiles will still blink the left led, which is the heat indicator.
Tekin should post a how-to video, including what the blinks look like for no timing, and with timing.
-Mike
bout time. Nice setup sheet.
Huh! I easily get 5 different RS setups with basically the same information on a single Excel-based spreadsheet that BadBoy gave me on a few months ago. That way I can better see how I progressed to the best overall settings. And don't waste so much paper.
I don't have the program to open that one on my laptop. So I never bothered with it. I'm not much of a paper guy. I save everything on my laptop. I agree though, that one is nicer.
Any spreadsheet program will do it. And with a laptop, you don't have to print them out either.
