Tekin RS ESC sensored
Your cars will feel less punchy now that the throttle is smoother, fact. Just because it feels less punchy doesn't mean it is, what you need to look at are your lap times, not the feel. Your car will be easier to drive and a car that is easier to drive is faster, but often feels slower.
You can make the car feel more punchy by changing rev ranges and/or throttle profiles, but it wouldn't surprise me if some of you actually go slower if you do that.
As I and others have said, always look at your lap times.
Trev
Trev
I'm digging me some 208 today. Nice and smooooooooth with great brakes.
Hi guyz, i have big problem with my RS Just recieved Hotwire today, i´v been very looking forward to great performance increase against not updated RS, downloaded v. 208, updated, setuped, and.. nothing happend car is still so so slow and don´t break at all! i´v tried so many possible setups and nothing helped, still the same anybody know where can be mistake?
Car is Xray T2008, motor LRP X12 17.5T (-5 Timing), FDR 7.3, transmitter LRP C3 Pro..
I´ve noticed that when i manually spin the wheels at the car, nothing at the ESC blinks, is it normal? Thanks very very much for help..
Are you sure that the sensor harness is plugged in all the way on the motor and ESC.
Other things you may want to change in your setup are:
Neutral Width : 10
Motor Type : BL-FW
Start RPM : 5000ish
When you calibrate the ESC to your radio set your throttle EPA down by 10% and then when you have completed the calibration set the throttle EPA back up by 10%.
Neutral Width : 10
Motor Type : BL-FW
Start RPM : 5000ish
Neutral Width : 10
Motor Type : BL-FW
Start RPM : 5000ish
Neutral Width : 10
Motor Type : BL-FW
Start RPM : 5000ish
Remember that you need to recalibrate the ESC to your transmitter every time you load a new version of the software onto the ESC. I think that may be the problem.
Trev
Martyn666:
Looks like the RS is running Dual mode instead of Sensored mode.
Your settings looks fine. But the part you mentioned no blinking lights (#5,#6,#7) when you turn your motor/wheel indicates the sensor is not working.
You may try the following:
1) try a different sensor wire
2) try a different sensored motor
good luck.
good luck.
Thanks a lot!! It was the sensor wire, borrowed another from friend and now it´s really "flying" so much power, i´m really impressed
So i can keep that my settings i have now? Except that things Skitee write..
Thanks again for great forum, great people and great ESC!
Anyone have a setup for a LRP X12 13.5 1c 3.7 lipo on a 50x25ish track also I would need the gearing im using a 76 spur with a 1.72 rear tire. I never ran this motor before have no clue where to start.
Problem:
After installing the new software and recalibrating all the parameters ( including TX) after doing all the stuff that is need ed to be done then when I would power up my speedo there would be blinking lights but no BEEPING sound and speedo won't store the settings it would do nothing.
HELP please.
HELP please.
Problem:
HELP please.
HELP please.
Problem:
HELP please.
HELP please.
Bill
Hello there,
The motor is stock right out of the box I didn't even run it yet.where should I set it at ? And what gearing for a 50 x 25 carpet track with a 76 spur and a 1.72" inch tire
Also what would be your tekin settings for this motor?
