New TEAM WAVE racing brushless system >
Old 05-26-2010, 12:12 AM
  #1351
decibels's Avatar
Hey guys havn't posted for a while but my brother makes up for me!!
But last night i tried 3x 17.5 motors all geared with a fdr of 4.1, and the results were interesting. Each motor gave different handling but around the same speed.
Firstly x12 0000 insert, time shift was set to 7 and no turbo and gain was 2. Now the car was very stable with this motor explosive bottom end and very linear to top speed.
Secondly novak ss timing to minimum, time shift 9 turbo 1 gain 2 and kick in at setting 6, car was extremely smooth and felt like it had a lot of positive grip and was punchy at mid speed so in other words as you would exit a corner it would want to shoot out.
thirdly duo 1 no timing, time shift 9 turbo 1 gain2 and kick in at setting 6. Now this motor was explosive at a point in between low and mid speed. So if you got on the power to soon it would kick sideways wildly and then step back in. So you had to drive it differently.
But all in all all 3 motors to me were the same speed but gave different handling characteristics to the car. So this is something to keep in mind when you are choosing your motor.
Also i drove with no body on and on low grip to feel the exact character of the car.
On another note the x12 will run the hottest, the other 2 similar but the duo will handle heat better than the novak. Hope this information is useful!!
decibels is offline
Old 05-26-2010, 06:15 AM
  #1352
Originally Posted by Dragonfire
I would love for it to be out soon but we are waiting on two different versions to be finished 1st. I also have to complete the guide. I hope it will be this week still.
Hi
What Model esc do you suggest for 17.5 and 13.5 to be able to compete competitive at National level.
2Quick is offline
Old 05-26-2010, 07:02 AM
  #1353
Originally Posted by 2Quick
Hi
obviously the RB-S
mtaddei is offline
Old 05-26-2010, 10:13 AM
  #1354
ATLASCOPCO's Avatar
Hi do i still need to set the throttle to reverse or dose it not matter
Cheers
ATLASCOPCO is offline
Old 05-26-2010, 12:18 PM
  #1355
Johnny Wishbone's Avatar
Cheers
There are 4 of us that run RBS/RB50 speed controls here and everyone has the throttle set to normal, none of us could get it to work when in reverse. Don't know if thats right or wrong, but it works for us in normal.
Johnny Wishbone is offline
Old 05-26-2010, 01:46 PM
  #1356
I also use forward as opposed to reverse on the throttle. There are differences between the various brands of radio's so maybe the requirement of reverse is particular to a certain brand(s). With the modern ESC I can't understand why it matters at all.
Dragonfire is offline
  #1357
ATLASCOPCO's Avatar
What problems were you having then
Old 05-26-2010, 03:45 PM
  #1358
It would not work when we have the throttle option set to reverse, or I should say, throttle was when brake is applied, and all brake when normal throttle applied. When the reverse is set to normal it operates properly.
I have to agree with Dragonfire, I think its written with certain radio intention.
The weird part is I can get it to work on setup with LRP speed controls, normal or reverse, all done in the setup mode. But it doesn't work with the Team Wave.
Atlascopco, If you have a trick to get this to work, please inform us.
Old 05-26-2010, 08:42 PM
  #1359
tandman's Avatar
Lanzer, maybe you can help me on this one. I can upload the previous software versions but the 202 says that there is an error and it will not upload. What do I do
tandman is offline
Old 05-26-2010, 08:46 PM
  #1360
Snow Rider's Avatar
Hi Max, really liking the look of this new software update. 2 of us are running team wave's at PRECC and one had updated software last night and WOW... Looking forward to updating mine for test n tune this sunday...
Snow Rider is offline
Old 05-27-2010, 05:10 AM
  #1361
decibels's Avatar
sometimes it will fail and after a couple of goes will work!! Don't know why but thats computers for you!!
decibels is offline
Old 05-27-2010, 08:34 AM
  #1362
Welcome to my world! I'm not sure why but some speedies take a few to update firmware possibly just a dirty connection? Anyway if it starts playing up when u/ling firmware I just switch off the transfer (switch on program box), give it abiut 10secs and then start again. For my speedy it usually works 2nd or third attempt. Every other esc I have updated works 1st attempt so the problem is not common.
Old 05-27-2010, 09:04 AM
  #1363
Senna Racing's Avatar
HA you Guys comin to CC10 Rd2 to show us this new awesome power
Senna Racing is offline
Old 05-27-2010, 10:11 AM
  #1364
I would have thought you already knew the answer to this...
Old 05-27-2010, 04:03 PM
  #1365
ATLASCOPCO's Avatar
No i dont have at trick for you , i can only get it to work set into the reverse position and it works fine .
I went out for the first time with the new firmware and it was FANTASTIC super quick what a good job that he guys have done im well impressed
i was running 10.5 on a large carpet track with the gear ratio at 5.7 and a novak ss .
I found it a bit wild exiting the corners could someone recommend a setting ajustment that would not affect the top speed , i think drive profile
Cheers
Simon
