Team Magic E4 Thread
#3691
Hi,
I also had some ideas so I have tried to make a new chassis. What do you think?
Allover the chassis is a little bit narrower. It should give enough flex at the rear, the front is more stiff, but I think it will be to stiff^^
I also made new topdecks, because the new chassis will have a little bit less flex now, the topdeck should have more, especially at the rear. But here also I think it´s to stiff at the front. I will change some parts after my exams and if I get some money I will try out this.
#3692
#3693
Nice work Seb!
I thought I'd share a couple of pics.
I managed to cut the prototype from 2mm material. It's a bit twisty but did work quite well last weekend. Very smooth and consistent. I've got some irons in the fire to hopefully get some production versions made by summer. I made a few small modifications (not shown in these pics) to make parts fit better and a mod to the upper deck as well. I like it so far so I will keep moving forward with this project.
#3694
Nice work Seb!
#3695
So the battery is just taped in? Whats holding it from moving side to side other than the tape? Will you be planning any additional chassis pieces that would hold the battery in place allowing the battery to be installed without tape with just the top and bottom plates sandwiching the battery?
I want to avoid having the battery contact the upper brace as it will influence the flex of the brace. This is a problem for those who squeeze in a pack that is a bit too tall into the space. The upper deck must be free to twist and flex for it to be effective and consistent.
#3696
I may implement some brackets but the battery sits in a pocket which will keep it from moving around.
#3697
Hi,
you are right, it is very important that you have enough space between top of the LiPo pack and the Top Deck, to make sure the Chassie can work with the Flex. I used shims under the Top DeckScrews and have now minimum space of 1mm with the newest LiPo Packs.
I have a open Case by SpecR, if they can build a Gear Diff for the E4, some drivers here in Germany are using it (Yokomo and Tamiya) in rear and in front, it works perfect and give a lot of more steering and out power of the corners.
See you soon,
Marcel
See you soon,
Marcel
#3699
I think he meant that they make gear diffs for the two other cars and is asking them if they will make one for the E4, not that they actually fit our cars.
#3702
Been running Yodogs rear spacer and now i have a "problem"
I got a very planted rear end now and have to adjust it or the front to get more steering
In fast sweepers i need to get of the throttle to get it to turn in,otherwise i will end up outside the track
The car is very different to drive after placing the rear damper spacer,but in a good way.
Fastest track time for me stayed almost the same but average time has gone down a lot
Now i need to dail in the front end.
This was a first for me that i didn't have enough steering with the TM E4RS.
Shame that one of the nitro guys smashed into the rear of the car and broke a rear axle,the only part i didn't carry with me
Will try next week to get the front dailed in again.
Yodog? Many thanks for the parts
They work like a charm.
regards Roy
.I got a very planted rear end now and have to adjust it or the front to get more steering
.The car is very different to drive after placing the rear damper spacer,but in a good way.
regards Roy
#3705
Just driving the hell out of this great chassis. Now have 3 E4FS cars. Stocking up on parts deals when I can. Concentrating on VTA right now and this chassis is just outstanding for it.
Anybody heard any more news about the updated E4 from Team Magic ??
