Team Magic E4 Thread >
Old 03-22-2010 | 06:25 PM
  #3106
billjacobs's Avatar
Default making graphite parts
If you cut, sand, or mill graphite, please wear a dust mask. Graphite and figerglass dust is BAD for your lungs.
billjacobs is offline
Old 03-22-2010 | 06:31 PM
  #3107
YR4Dude's Avatar
A little late for that but will do for next time. Thanks for the advise.
YR4Dude is offline
Old 03-25-2010 | 07:18 AM
  #3108
T Racer's Avatar
Default starter setup
Morning Guys
Just purchase new E4. I would like a starter setup for VTA class.
Thanks much
T Racer is offline
Old 03-25-2010 | 07:26 AM
  #3109
T Racer's Avatar
Default carpet
Oh Yes carpet setup
T Racer is offline
Old 03-25-2010 | 10:14 PM
  #3110
Jochim_18's Avatar
ok guys got my E4 good to go I purchase the CF lipo spacer from wolf hobbies and change my steering to a single bell crank and walla problem solve on fitting big lipo packs....
I'll give it a go this weekend on mod class....
Jochim_18 is offline
Old 03-26-2010 | 11:26 AM
  #3111
YoDog's Avatar
Will you be running at XS?
It's good to see another E4 out there. I've got to go out of town this weekend but plan to be at the next race with my E4.
How are the belts holding out in MOD? I have a new 2009 that I would like to set up for mod in addition to my 13.5 car.
See ya there!
YoDog is offline
Old 03-26-2010 | 06:07 PM
  #3112
Jochim_18's Avatar
I just got the front wide belt but last time I race Mod I stripped it... I just put it together but might not run in this weekend. I've been running schumacher this past couple of years... I will be as XS Speedway this weekend to race 13.5 and Mod
See ya there!
Old 03-28-2010 | 01:54 AM
  #3113
Humyu's Avatar
Default E4 skipping
Hi guys, bought my e4 from a friend. First was running ok. But lately my e4 sounds like the belt is skipping. Already chg new belts all 3. change all four small pulley. but still sound like the belt is skipping, specially initial start and coming out of corners.I'm running 11.5t motor and Sp GT2.0Pro. Sorry for my bad English. And appreciate the help from seniors
thnks
Humyu is offline
Old 03-28-2010 | 08:33 AM
  #3114
thnks
Your forgot about the rear diff and front diff pulleys......believe it or not, I did the EXACT same thing like you did, side belt 1st, then 2 short belts, then all 4 small pulleys....then the last 2 diff pulley, not untill I replaced that last 2 pulleys and the skipping sound disappear...
BTW...you cannot leave the belt too loose. Especially if you ran for outdoor. Also, the K-factory belts does make the situaion better...(less skipping sound)
Solara is offline
Old 03-28-2010 | 09:45 AM
  #3115
Originally Posted by T Racer
Morning Guys
Thanks much
JS or RS/FS?
i ran a js ...it was hooked ! AE blue's and green springs ..makes the ride hight a little high but u can get TC5 shock retainers to lower it ....spool is awesome and swaybars rock other then that stocks pretty good !
rkhess is offline
Old 03-28-2010 | 05:37 PM
  #3116
YR4Dude's Avatar
I've also been experiencing that. So is the fix to just replace the diff gears or do I have to replace everything? Also how long will it last until the skipping sound comes back? Is this a chronic problem? Is there a certian kind of pulley that can eliminate this problem for good?
Thanks in advance.
YR4Dude is offline
Old 03-28-2010 | 05:42 PM
  #3117
wyd's Avatar
wyd
Tech Legend
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
You really need to keep the belt tensions set on the E4 so you don't get the skipping of the belt sounds. I know when I didn't have them set my belts would skip but when I went and get each belt tension right it went away.
wyd is offline
Old 03-28-2010 | 06:15 PM
  #3118
YR4Dude's Avatar
How do you adjust tension? Unlike other cars, I don't see anything on the diff bulkheads that allow for belt tension adjustments. Other cars like XRay or Tamiya have eccentrics on the diff bearing holder to allow for belt tension adjustment. Is there a way of adjusting tension that I don't know about? BTW the instructions I got were worthless. Can you shed some light on this?
YR4Dude is offline
Old 03-28-2010 | 06:34 PM
  #3119
YR4Dude's Avatar
Okay, I just looked at the exploded view again and had to squint real hard.
I found this part.
http://www.wolfhobbies.com/product.c...7&product=8688
It mounts on this part on the middle lobe. I've always wondered what that was for. Now I know.
http://www.wolfhobbies.com/product.c...7&product=8689
YR4Dude is offline
Old 03-28-2010 | 09:28 PM
  #3120
Pro10noob's Avatar
That is for the rear belt
The other pics are for the side and front belt.
regards Roy
I found this part.
Attached Thumbnails Team Magic E4 Thread-e4fs-3.jpg   Team Magic E4 Thread-e4fs-4.jpg
Pro10noob is offline
